Wifi Server not visible
Hello.
I have a strange problem with PLEX. My server is installed on
Windows 10.
When this one is connected to my LAN in ethernet, it is well visible. However, when I switch to WIFI, the server seems to work but is not visible by the other devices on my network.
(And yes, I prefer my Wifi network, because it’s faster than my 100Mb ethernet that goes through my walls)
Server 1.22.1.4228
  1. In general, avoid using WiFi for your plex server.
  2. after switching network connections, you need to stop Plex server and restart it. (And hope that all your clients are quick enough to react to this change.)
Thank you,
Already done. I even uninstalled and reinstalled everything on Wifi, it doesn’t work…
