Will an Andriod TV's built in tuner be recognized?
Hi all, will the built-in work? or do you need a devoted tv tuner? TV is the sony bravia x850
No. Plex server is not running on your TV, only the client. The tuner on your TV is not accessible for plex server. You need a compatible tuner to work with plex media server.
Is a comparable tuner something we need to purchase or download?
@jlyons360
Is a piece of hardware like the HDhomerun Connect, expand or prime. You need also an antenna to receive the OTA signal or a cable card with a cable subscription for the prime. There is also some usb and PCI tuner.
More detail here:
https://support.plex.tv/hc/en-us/articles/225877427
