http://www.hauppauge.com/pages/products/data_quadhd-usb.html
I would post a screenshot with tuner add in but apparently we can’t do that here
Hey @shspvr, does this Hauppage WinTV-quadHD USB works well ?
Your screenshot suggest it does get added to Plex but will it work properly afterward ?
Thank you
Any luck getting this to work? I ordered it before I realized that the USB version is a brand new product. Hauppauge hasn’t released Linux drivers as of yet, and I don’t have a windows device to test it on with Plex. Hauppauge support said the Linux driver should be out soon.
I did not order it yet. I was waiting for an answer to my other post before buying: Is the WinTV-quadHD USB working
Hey @tassadar1981, had a chance make your quadHD USB work on Windows ?
Does anyone know for sure if the QuadHD -USB tuner works with Plex? In the picture above it looks like it gets identified as two dual tuner cards and works.
Work just fine in ever DVR app I test hope lee soon will see linux.
And yes you see two identified as two dual tuner
