@ClosestStorm said:
Launched opera plex html5 tv edition just loaded it in iptv browser worked great but wrong ratio any ideas
Is legit
managed to get full screen on my TV type in http://plex.tv/web/tv/lg into panaconic iptv browser still need figure out how to get remote working instead of mouse
hope this helps
@ClosestStorm said:
Any one have any ideas? I think the Panasonic’s SDK is newer then Firefox’s since they have discontinued b2g for phones and I’ve Noticed user agent is chrome on IPTV version
@shippi said:
Did you tried to change the redirect URI in the index file?
Mine works fine with the “/lg” at the end… but I think it could be related to the resolution of the TV, I just got one with HD, maybe UHD is causing the issue here.
Yes redirected the index file also tried changing the launch_path.
Maybe but the Panasonic html5 app, goes full screen. I have tried the the other tv web apps as well but comes out even smaller. I know plex isn’t in uhd yet so your probably right.
Actually stil not working stuck at sign after linking account ide’s say something todo sentry version
@shippi said:
I also tried stripping the Webapp from the PMP but no luck there, most of the code relies on qt.
i’ll set up a proxy later, download the app to my mac and download the htmla5 app. Panasonic really need to update there SDK and there links for smart http://smarttv-alliance.org
