Worth it to upgrade for free? I’m clueless with hardware…
Server Version#:
<If providing server logs please do NOT turn on verbose logging, only debug logging should be enable
Currently running an i5-4670k with a Nvidia quadro 4060. It’s at least 11 years old but works fine for what I needed using Plex with Unraid
Inherited for free a desktop with a 13th gen i7-3700 2.10 with Nvidia GeForce rtx 4060.
Is it a no brainer to swap my hard drives from my current setup into my new one? Is both the CPU and GPU a major upgrade? Same amount of RAM (16GB) in both
At least for the CPU it would be almost a downgrade. The difference is so small, that you won’t feel it.
Your current CPU has a tiny advantage with single thread loads. And that is still very important for many workloads in Plex.
I don’t know enough about the differences between the various product lines of nVidia GPUs to tell if the Quadro would have an advantage. It might have a bigger number of video transcoding slots. If it fits, you could try to swap out only the GPU.
There’s no such thing. If it is a typo and you meant “i7-13700” then that’s a heck of an upgrade!
You do not even need to use the Nvidia GPU if that Intel CPU is the variety with a built-in GPU – it’s excellent for everything Plex. Use the Nvidia card for another gaming system, or maybe sell it and buy storage for your fancy new Plex server.
Use 13th Gen i7 GPU or GeForce RTX 4060?
Server Version#:
Pretty much just what the title says? Which one should be used for transcoding? Thanks for the help!!
[mod-edit: moving this into your existing thread]
