Writing metadata to movie folder
When you add a movie to plex it downloads posters and info and even subtitles if you have enable it. Som my question is can i make it so that plex adds all that to the folder my movie is stored in.
Say for example i have Aquaman in a folder and it gets added to plex and plex gets all of the stuff for it. The stuff it finds can i make it so it gets added to the same folder Aquaman is in?
Not native, as @flow already said, but there’s a 3.Party plugin that might help here:
SNIFF, but sadly so.
Note though, that the solution I pointed towards, is an agent, and they’ll hang around a tad longer
I tried to install webtools and i says its installed
But when i try to access it from http://127.0.0.1:33400/ nothing happens it doesn’t exist.
What am i doing wrong?
You are asking for WebTools Support, but not in the WebTools thread!
Doing so makes it harder for others to find a solution, as well as answer!
When said, use the easy installer, linked to in the WT Opening post
Sorry for that i used the easy installer now and it works great.
