example of not working files :
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2094 App 4, Version HDR10+ Profile B, HDR10+ Profile B compatible
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2 h 1 min
Bit rate : 24.5 Mb/s
Width : 3 824 pixels
Height : 1 592 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0 (Type 2)
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.168
Stream size : 20.8 GiB (96%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 183 cd/m2
Maximum Frame-Average Light Level : 61 cd/m2
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : SMPTE ST 2086, HDR10 compatible
Duration : 2 h 6 min
Bit rate : 12.6 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.063
Stream size : 11.1 GiB (90%)
Default : Yes
Forced : No
Mastering display luminance : min: 0.0001 cd/m2, max: 1000 cd/m2
Maximum Content Light Level : 972 cd/m2
Maximum Frame-Average Light Level : 511 cd/m2
Format : HEVC
Duration : 1 h 54 min
Bit rate : 24.3 Mb/s
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.166
Stream size : 19.4 GiB (96%)
Default : Yes
Forced : No
Maximum Content Light Level : 439 cd/m2
Maximum Frame-Average Light Level : 107 cd/m2
EDIT : Ok I was wrong, this file and some others I found in my library are transcoding fine … I can’t find the cultprit then…
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : Dolby Vision, Version 1.0, Profile 8.1, dvhe.08.06, BL+RPU, no metadata compression, HDR10 compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Duration : 1 h 32 min
Bit rate : 20.4 Mb/s
Height : 1 608 pixels
Display aspect ratio : 2.39:1
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.138
Stream size : 13.2 GiB (80%)
Default : Yes
Forced : No
Maximum Content Light Level : 970 cd/m2
Maximum Frame-Average Light Level : 340 cd/m2
Format : HEVC
Duration : 3 h 8 min
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.165
Stream size : 32.3 GiB (95%)
Default : Yes
Forced : Yes
Maximum Content Light Level : 686 cd/m2
Maximum Frame-Average Light Level : 404 cd/m2
