I have set default subtitles to polish. In new Plex player even that settings have English subtitles.
Server Version#: 1.16.3.1402
Player Version#: 1.0.0.792
XML attached, information about subtitles attached. I supposed that played non forced English subtitles.
johny.xml.zip (31.5 KB)
Sorry, this is not a XML file. Did you compress it twice or something?
Sorry, I can’t use this.
Simply copy & paste the XML text into the message editor.
message is to long,
I reduced the XML to the relevant portion
<Media id="115134" duration="7864916" bitrate="14416" width="1920" height="800" aspectRatio="2.35" audioChannels="6" audioCodec="dca" videoCodec="h264" videoResolution="1080" container="mkv" videoFrameRate="24p" audioProfile="dts" videoProfile="high">
<Part accessible="1" exists="1" id="116093" key="/library/parts/116093/1565788101/file.mkv" duration="7864916" file="/media/FilmyHD/John.Wick.3.2019.1080p.Bluray.X264/John.Wick.3.2019.1080p.Bluray.X264.mkv" size="14176800057" audioProfile="dts" container="mkv" deepAnalysisVersion="4" indexes="sd" requiredBandwidths="22352,18202,16573,15486,14919,14919,14919,14919" videoProfile="high">
<Stream id="260767" streamType="1" default="1" codec="h264" index="0" bitrate="8927" bitDepth="8" chromaLocation="left" chromaSubsampling="4:2:0" colorPrimaries="bt709" colorRange="tv" colorSpace="bt709" colorTrc="bt709" frameRate="23.976" hasScalingMatrix="0" height="800" level="41" profile="high" refFrames="4" requiredBandwidths="19282,12584,10146,9494,9267,9267,9267,9267" scanType="progressive" width="1920" displayTitle="1080p (H.264)"/>
<Stream id="260768" streamType="2" selected="1" default="1" forced="1" codec="dca" index="1" channels="6" bitrate="1509" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="dts" requiredBandwidths="1509,1509,1509,1509,1509,1509,1509,1509" samplingRate="48000" title="DTS" displayTitle="English (DTS 5.1)"/>
<Stream id="260769" streamType="2" codec="dca" index="2" channels="6" bitrate="3980" language="English" languageCode="eng" audioChannelLayout="5.1(side)" bitDepth="24" profile="ma" requiredBandwidths="4941,4663,4369,4369,4369,4369,4369,4369" samplingRate="48000" title="DTS-HD" displayTitle="English (DTS-HD MA 5.1)"/>
<Stream id="260770" streamType="3" codec="srt" index="3" bitrate="0" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" title="English-Full" displayTitle="English (SRT)"/>
<Stream id="260771" streamType="3" default="1" forced="1" codec="srt" index="4" language="English" languageCode="eng" requiredBandwidths="1,1,1,1,1,1,1,1" title="English-Forced" displayTitle="English Erzwungen (SRT)"/>
<Stream id="260898" key="/library/streams/260898" streamType="3" selected="1" codec="srt" language="polski" languageCode="pol" format="srt" displayTitle="polski (SRT Extern)"/>
</Part>
</Media>
Were you playing the original or a “Downloaded” version of this movie?
original
Confirmed. Apparently, the app prefers embedded subs instead of external ones.
Filed as a bug.
Thanks for reporting it!
