Server Version: 1.22.3.4392
The wrong year is displayed on my homemade videos loaded as Other video Library and I don’t understand from where is that date.
Here is an example of two of my videos right after library initialization:
Video 1 - Wrong year is displayed:
ExifTool Version Number : 11.88
File Name : Chata pod suchym (2019).mp4
Directory : .
File Size : 717 MB
File Modification Date/Time : 2021:04:24 11:52:35+02:00
File Access Date/Time : 2021:04:24 11:52:40+02:00
File Inode Change Date/Time : 2021:04:24 11:52:35+02:00
File Permissions : rwxr--r--
File Type : MP4
File Type Extension : mp4
MIME Type : video/mp4
Major Brand : MP4 Base Media v1 [IS0 14496-12:2003]
Minor Version : 0.2.0
Compatible Brands : isom, iso2, avc1, mp41
Movie Header Version : 0
Time Scale : 1000
Duration : 0:02:30
Preferred Rate : 1
Preferred Volume : 100.00%
Preview Time : 0 s
Preview Duration : 0 s
Poster Time : 0 s
Selection Time : 0 s
Selection Duration : 0 s
Current Time : 0 s
Next Track ID : 3
Track Header Version : 0
Track Create Date : 2019:10:19 15:00:00
Track Modify Date : 2019:10:19 15:00:00
Track ID : 1
Track Duration : 0:02:29
Track Layer : 0
Track Volume : 0.00%
Image Width : 2704
Image Height : 1520
Graphics Mode : srcCopy
Op Color : 0 0 0
Compressor ID : avc1
Source Image Width : 2704
Source Image Height : 1520
X Resolution : 72
Y Resolution : 72
Bit Depth : 24
Video Frame Rate : 60
Matrix Structure : 1 0 0 0 1 0 0 0 1
Media Header Version : 0
Media Create Date : 2019:10:19 15:00:00
Media Modify Date : 2019:10:19 15:00:00
Media Time Scale : 44100
Media Duration : 0:02:30
Media Language Code : und
Handler Description : SoundHandler
Balance : 0
Audio Format : mp4a
Audio Channels : 2
Audio Bits Per Sample : 16
Audio Sample Rate : 44100
Handler Type : Metadata
Handler Vendor ID : Apple
Encoder : Lavf58.29.100
XMP Toolkit : Image::ExifTool 11.88
Date/Time Original : 2019:10:19 15:00:00
Metadata Date : 2019:10:19 15:00:00
Media Data Size : 751133167
Media Data Offset : 188448
Image Size : 2704x1520
Megapixels : 4.1
Avg Bitrate : 40.2 Mbps
Rotation : 0
Video 2 correct year is displayed:
File Name : Ducati Day Banska Stiavnica (2019).MP4
Directory : .
File Size : 91 MB
File Modification Date/Time : 2021:04:14 00:19:50+02:00
File Access Date/Time : 2021:04:24 11:41:26+02:00
File Inode Change Date/Time : 2021:04:14 00:25:03+02:00
File Type : MP4
Major Brand : MP4 v2 [ISO 14496-14]
Minor Version : 0.0.0
Compatible Brands : mp42, mp41
Time Scale : 90000
Duration : 0:01:14
Preferred Rate : 1
Preview Time : 0 s
Poster Time : 0 s
Current Time : 0 s
Next Track ID : 3
Track Create Date : 2019:08:15 06:37:18
Track Modify Date : 2019:08:15 06:37:18
Track ID : 1
Track Duration : 0:01:14
Track Layer : 0
Image Width : 1920
Image Height : 1080
Op Color : 0 0 0
Source Image Width : 1920
Source Image Height : 1080
X Resolution : 72
Y Resolution : 72
Compressor Name : AVC Coding
Bit Depth : 24
Media Create Date : 2019:08:15 06:37:18
Media Modify Date : 2019:08:15 06:37:18
Media Time Scale : 48000
Media Duration : 0:01:14
Media Language Code : eng
Balance : 0
Handler Description : Alias Data Handler
Audio Format : mp4a
Audio Channels : 2
Start Timecode : 00:00:00:00
Genre : MotoTrip
Content Create Date : 2019
XMP Toolkit : Image::ExifTool 12.16
Windows Atom Extension : .prproj
Windows Atom Invocation Flags : /L
Format : H.264
Date/Time Original : 2019:08:09 20:00:00
Orientation : Horizontal (normal)
Create Date : 2019:08:15 08:37:17+02:00
Creator Tool : Adobe Premiere Pro 2019.1 (Macintosh)
Metadata Date : 2019:08:15 08:37:59+02:00
Modify Date : 2019:08:15 08:37:59+02:00
Alt Timecode Time Format : 60 fps
Alt Timecode Time Value : 00:00:00:00
Audio Channel Type : Stereo
Audio Sample Rate : 48000
Audio Sample Type : 16-bit integer
Duration Scale : 1.11111111111111e-05
Duration Value : 6698880
Project Ref Type : Movie
Start Time Sample Size : 1
Start Time Scale : 60
Start Timecode Time Format : 60 fps
Start Timecode Time Value : 00:00:00:00
Video Field Order : Progressive
Video Frame Rate : 60.000000
Video Frame Size H : 1080
Video Frame Size Unit : pixel
Video Frame Size W : 1920
Video Pixel Aspect Ratio : 1
Instance ID : xmp.iid:3cae5798-05f8-43f2-96f3-3a1550d40817
Original Document ID : xmp.did:af15bffe-2541-4d0a-a28e-0bed8be2732c
Pantry Title : I'm Just an Accident Waiting to Happen (Instrumental Version)
Pantry Artist : Basixx
Pantry Composer : Anders Lystell, Michael Stenmark, Linda Stenmark
Pantry Genre : Dance
Pantry GPS Latitude : 48 deg 30' 42.84" N
Pantry GPS Longitude : 18 deg 59' 45.24" E
Pantry Orientation : Horizontal (normal)
Pantry Create Date : 2019:08:09 13:46:14Z
Pantry Metadata Date : 2019:08:13 23:26:50+02:00
Pantry Modify Date : 2019:08:13 23:26:50+02:00
Pantry Duration Scale : 8.33333333333333e-06
Pantry Duration Value : 51133440
Pantry Document ID : a9916c7c-18ad-e99c-0388-bbd400000043
Pantry History Action : saved
Pantry History Changed : /
Pantry History Instance ID : f361de59-8d2f-8174-099a-b05d00000070
Pantry History Software Agent : Adobe Premiere Pro 2019.1 (Macintosh)
Pantry History When : 2019:08:13 23:26:50+02:00
Pantry Instance ID : f361de59-8d2f-8174-099a-b05d00000070
Pantry Original Document ID : xmp.did:c84ab6d7-a339-49a0-8da5-f8881f44278e
Media Data Size : 94970003
Media Data Offset : 146284
Image Size : 1920x1080
Megapixels : 2.1
Avg Bitrate : 10.2 Mbps
Rotation : 0
