Please could you add a XMBC nfo importer agent in the next version of PLEX ?
They are differents nfo importer agent here in the forum but they don’t work on the SYNOLOGY PLEX version, so if you could add this feature directly in PLEX it could be very comfortable for all like me who have medata in nfo file coming from XBMC or Filmotech or AntMovieCatalog or any other software
There are no plans to add NFO support to Plex beyond the 3rd party NFO agents already found in the forums.
I'm in France, I have separate folders for each movie but the XBMC nfo Impporter begin to work and stop ... here attached the log file
It seam that each time he Agent XBMC nfo Importer do not find a file (this case it was because uppercase and lowercase different) the agent stop all
Do you have an idea of what I could do ?
Thank's for your help
Pierre-Jean
track down the agent author and ask them to fix/update it.
ok I'll do it
Would it be possible that in the next version of Plex you incorpore a UPnP server for product not DNLA compatible ?
