Xbox One App worse than before also does not display everything
Xbox one now updated to the latest plex app (2.0.1.6)
First:
Xbox one does not display everything in my Mediaserver. I have different media libraries for different countries to use different scanner and different agents (i.e. Anime, US Series, Korean Series).
All of the are marked as type (TV Series). The plex app now takes the first library of the type and tells me that would be everything of the type I have. Which is very, very wrong. Currently I do not have any way of accessing the other libraries using the plex app.
Now for my generell feedback:
  • I would like to have the dashboard back, so I have an overview of the last watched series and can continue to watch them after addin new episodes
  • I would like the media library centered views back instead of the view by type. Also the dashboards by media library were great to filter.
  • Currently I would rate I zero of 5 stars if that was possible because it is unusable for my cases.
Please restore the functionality as soon as possible and think about the generell feedback i provided.
Best regards
miracle152004
Hi there
You can access other libraries by pressing up from the media type buttons on the dashboard. Out of curiosity, did you go through the first run message when you first updated the app?
That’s still present. If you highlight any library it will show a dashboard for that library with on deck.
ok, I have to correct me.
I have seen the first run message (the first) and followed it and did not see, that it changed.
So I have done what the first message told me and then pressed A which brought me to the whole media library. And clicking on the home button only moved me back to the first run message (the first) which left me in the impression that the dashboard was missing.
Maybe it would be better to have more visuell feedback that the message changed.
Thanks for the fast feedback.
Guys…please please please please please fix the new UI to something non sucky. This is a really bad update to try to use with a remote. Check the feedback on Reddit…I’m not alone in my displeasure with this update.
I use it with the remote and don’t have any problems …
Apart from the known issues Moussa has already confirmed (FF not possible, Stop button sometimes not working)
