I can use the tiles in the On Deck section to view and watch the next episode in a TV series I’ve been watching. Either before I watch that episode or after it finishes showing I can use the navigation buttons in the top right corner to move to the previous/next episode in the series. Great!
However, if I use the three dots on the main screen On Deck section to view more TV show options, and access TV shows I’m currently watching from there, then the same previous/next episode buttons don’t work. They typically jump to the 1st episode of the 1st season.
It’s only a minor bug because if I use the extended list of On Deck TV shows to watch an episode and go back to the main screen then the correct next episode shows up in the On Deck. It’s just that I can’t sneak a look at the synopsis of the next episode immediately after watching an episode; I have to go back to the main screen to navigate to the next episode.
I can reproduce it every time I try.
Has anyone else noticed this and/or can reproduce it?
Is it a known bug?
