Xbox One Media Remote
Hi - is the Xbox One Media Remote supported with Plex? I mean does it actually work well? Thanks!
I own it...it works great
I don't really have anything else to add...it works exactly like it should
Only issue is on netflix sometimes it doesn't work for whatever reason but if you reload the app that usually fixes it
it sure does and its amazing! the wife and kids love it!
