4. Movie view should have more rows (maybe 4?), or scroll up and down. When you get +200 movies I assume the 2 rows becomes a scrolling nightmare. Same deal with TV shows, obviously this effects people less though.
5. Possible Bug: When finishing a show, it does mark it as watched but the UI doesn't update/doesn't remove the dot.
#4. This is a design more in line with the xbox one design philosophy (horizontal scroll). I actually quite like it, if you go up there is a jump list to go to each letter of the alphabet. I've got over 600 movies and haven't had any issues using this.
#5. This is a documented issue that the team has said they are aware of and should be fixed.
thanks, I have been using the jump list without issue. I guess #4 will become less of an issue once filters are introduced. Using the Jump list is pointless if you are looking for a random movie to watch, or what I typically do and just cruise through my artwork until something catches my eye, or whoever is over etc. Its not a cruisable list with only 2 columns... trust me, it literally took my over 5 minutes to go from end to end, and that's with scrolling held down which means you can't really view much.
