XBOX Unexpected Error - File Format will not play
Hi
Just added Plex to XBOX 1 and have found files with container VOB will not play and get unexpected error. I have a few other formats and they play no problem so everything is connected and talking to each other - the Network is wired
The same VOB file plays on Plex Media Server and on Plex Home theater (PC, MAC Mini and Desktop, iPad) with no problem
Any suggestions appreciated
This is an example of the media info from the Media Server
Media
Video Frame Rate NRSC
Container = MPEG (but file extension is VOB)
Bit Rate 4471 kbps
Part
Container = MPER (file extension is VOB)
Video
Bitrate 4190
Scan Type Progressive
Frame Rate 23.976 fps
Color Space yuv
Bit Depth 8
Anamorphic 1
Codec MPEG2VIDEO
Audio
Bitrate 192 kps
Bit Depth 15
Codec AC16
Sampling Rate 48000Hz
Bitrate Mode CBR
change it to mp4.
I use mp4 and almost 95% of my movie files play direct! no transcode needed
I have thought of this already but in my case it is not a practical solution
My library has been built up over several years and I have several thousand video files in this format that will not play - I need a solution for the Xbox to work with this file format
