XML Fehler!?
Hallo,
wie bekomme ich die XML Fehler bereinigt?
DB Optimieren bringt hier nicht viel.
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: Entity: line 6:
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: parser
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: error :
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: Opening and ending tag mismatch: hr line 5 and body
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: ^
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: Entity: line 7:
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: Opening and ending tag mismatch: body line 3 and html
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: Entity: line 14:
Sep 20, 2017 20:25:48.964 [9548] ERROR - XML: Premature end of data in tag html line 1
Sep 20, 2017 20:25:48.964 [9548] ERROR - Error parsing content.
Sep 20, 2017 20:25:48.964 [9548] ERROR - Unable to parse downloaded XML document: Error parsing file
Sep 20, 2017 20:25:48.964 [9548] ERROR - IVA: Error downloading trailers for source 1.
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: Entity: line 6:
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: parser
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: error :
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: Opening and ending tag mismatch: hr line 5 and body
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: ^
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: Entity: line 7:
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: Opening and ending tag mismatch: body line 3 and html
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: Entity: line 14:
Sep 20, 2017 20:25:49.084 [9548] ERROR - XML: Premature end of data in tag html line 1
Sep 20, 2017 20:25:49.084 [9548] ERROR - Error parsing content.
Sep 20, 2017 20:25:49.084 [9548] ERROR - Unable to parse downloaded XML document: Error parsing file
Sep 20, 2017 20:25:49.084 [9548] ERROR - IVA: Error downloading trailers for source 2.
Sep 20, 2017 20:25:55.374 [7724] WARN - PubSubManager: Connection to 45.79.211.86 failed: Unknown error.
Sep 20, 2017 20:26:14.232 [9804] WARN - SLOW QUERY: It took 281.250000 ms to retrieve 75 items.
Sep 20, 2017 20:27:34.572 [3444] ERROR - [PlexRelay] kex protocol error: type 7 seq 11
Sep 20, 2017 20:27:34.722 [5380] INFO - [PlexRelay] Allocated port 2077 for remote forward to localhost:32401
Haben die denn irgend welche negativen Auswirkungen?
Guten morgen @OttoKerner ,
ich weiß es nicht. Zur Zeit habe ich nicht so wirklich Zeit was zu schauen, oder Querbeet was zu probieren.
Bis jetzt fiel mir nichts auf. Ich kann nur sagen, dass ich solche Fehler noch nicht hatte.
Was bedeuten Sie denn??
Ich kann dir nicht sagen was sie bedeuten, da wichtige Information nicht in deinem Log-Schnipsel enthalten sind.
Sag mir was du brauchst, bitte.
Na das komplette Log.
Hier der PMS.log
Das nützt mir leider gar nichts.
Ist debug logging aktiviert?
Bitte mach einen Neustart von Plex Server
dann 5 Minuten warten (bitte ohne Wiedergabe oder stöbern in der Mediathek!)
Danach log Dateien ziehen
Wird gemacht.
Wollte den Log gestern schon hier hochladen ging aber nicht mit dem IE.
Jetzt geht das anmelden auch nicht mehr mitm IE…Bleibt alles schwarz seit dem Plex die Anmelde Option erweitert hat.
Hier der PMS.log
Dieses Log enthält die Fehler nicht mehr.
Trailer werden von beiden Quellen erfolgreich herunter geladen, wo es vorher nur Fehler hagelte.
Das sah ich auch, weil ich vergessen hatte auf " Ausführlich zu stellen"
Und warum geht es wieder, wenn ich nichts gemacht habe um es zu “heilen” ?
Du sollst nicht auf ‘ausführlich’ stellen.
¯_(ツ)_/¯
Netzwerkprobleme behoben?
Ich dachte du wolltest mir damit sagen, dass ich diesen anmachen soll!? Denn mit debug an hätte doch der Log nicht so und so leer ausgesehen. Ferner steht dann doch auch immer Debug daneben !?
Nein. Hatte schon lange keine mehr.
‘Debug logging’ ist eine Checkbox
‘Ausführliches Protokoll’ ist eine andere
Ich will immer nur die erste, die zweite ist pfui. :wink:
Ferner steht dann doch auch immer Debug in der eckigen Kammer !?
Es geht darum, dass das Log nicht durch die Ausführlichen Meldungen (die in 98% der Fälle nichts zur Fehlerdiagnose beitragen) zugespammt wird.
Zumindest keine, die du bewusst wahrgenommen hast :wink:
Spaß beiseite, das kann auch auf Seiten von plex.tv gelegen haben.
Meinst du die unter den Web-Einstellungen???
:stuck_out_tongue:
Manchmal bin ich froh nicht alles wahrzunehmen. :slight_smile:
:slight_smile: Dann bin ich ja beruhigt.
Neiiiinnn!
Einstellungen - Server - Allgemein - ‘Erweiterte Einstellungen’
Die hatte ich doch angemacht!!!
:smiley:
Magst du mich veräppeln :wink:
Keine Ahnung ob Plex dann auch was am Protokol geändert hat, aber ich noch mit der 1.5.7 unterwegs durch Unzufriedenheit in den ff Versionen…
Ich habe durch die Kürze deines Protolkolls angenommen, dass ‘Debug’ nicht aktiviert ist.
Der erste war ohne…
und nach deinem Post:
Hatte ich ihn angemacht.
