XPlay (Android)
Submitted the app to Amazon App Store… Waiting for the QA team review
What could I say? I’m very surprised… It turned out that a client for Plex can “… encourages piracy or illegal download of content.”
I’ve asked how it is possible… Waiting on next answer…
Those guys are not serious, are they? The offical client IS available on the Amazon App Store…
Maybee they confuse your app with Kodi customizations?
I don’t know. I asked the same questions and described what the app does.
Now I can only wait…
Hello! You have done a really good job with your app and it works much better on Android than the orginal Plex app! However, I have discovered a mistake … if you decide that the next episode should not be played, it still continues to run, even if you put all devices in Seep mode.
DironDir- super appreciate the smartphone app
2 things that I would absolutely love to see implemented is GAPLESS playback for music and playlists integration.
Btw is there a music tab to were I can see all artist by anychance
Keep up the awesome work super appreciate it
Hi @lexx0006
Thank you for your opinion.
There is a bug with the “auto play next episode” option - it doesn’t work correctly.
What is your device? In the sleep mode player is paused and after waking up the player continues to play a movie/episode
Why do you think that the player works in the sleep mode?
Hi @jspurgeon09
Thank you for kind words :slight_smile:
Music is artificially limited in the app for smartphones/tablets because I need to adapt a player for this kind of media.
To be honest I thought that people use the app more for movies than for music. And started adaptation for movies first.
Device: Xiaomi Mi Box (Mod.: MDZ-16-AB) - Android 8
…when I put all my device sleep (sleep timer) the android tv usually stops playing immediatly, but at least at the end of the episode, but it plays episode after episode until I stop the replay manually (although it is set to stop in the setting).
I see.
Thank you for details.
I think next update will be released in several days. It will be fixed there.
Thank you very much! :sunglasses:
Forget xplay the developer is not serious pushing none working versions all the time
Sorry, but what did you mean?
Give, please, more details
Hey is xplay available on the firestick 4K yet? Or is there an eta? Thanks
Not yet…
My submission is processing by Amazon Apps Team
I do not understand why this remark ???
I think you’re wrong topic …
There are indeed problems with the application XPLAY for WEBOS (LG TV) but as for the android version, there is nothing to say!
@DironDir is very responsive!
After, if you’re not happy, go ahead, do better!
Hi everyone
The 1.0.38 version was published.
Stability improvements + fixed the issue with the Autoplay next episode option
Versions will be added in the next update…
On Monday I guess
Only just got my Sony AF9005 Android TV and started to use Plex. Then I have noticed this player. Will this one allow me to play material which is DTS encoded and pass that stream through optically…? I do know that the Plex app can’t do that and so I have to transcode the audio to DD 5.1.
Hi @Dibbler
Nice thing :slight_smile:
You know, I think that the app should play this content in the direct play mode, but I’m not 100% sure… There are a lot of nuances.
So you can try the app. If it doesn’t work you will be able to uninstall it and get refund.
