XPlay (WebOS)
this was his reply on 29th nov
@bublikoff said:
Yes I got new TV on webOS 3.x … finally And I go quite interesting experience with it.
Even current version of the app works quite fast and smooth … so much difference between webOS 1.x.
Ive also tested new version on it and already fixed some potential problems in source code and improved video player behavior. For the moment Im working on video player functionality and testing it for “smoother” experience
so looks promising hes working on improving the app for us
sorry forget that it was a bad file
Hello.
I have just discovered the application, and she looks very promising; it interests me a lot because my NAS is struggling to transcode my HD movies, that is to say that if I pause or that I mistakenly support the remote control the film will never resume, forced to launch from the beginning.
But with Xplay, the movie starts loading every 30 seconds, it’s a horror. A particular setting to do?
Thank you
@Arck0s said:
Hello.
Thank you
Probably need to check you wifi speed, preferably on the TV itself by visiting fast.com on the TV’s webbrowser.
I’m on ethernet cable
Try to disable secure connection in the network section of the Plex server configuration of your NAS.
This solved for me.
You’re my hero.
More than that, you’re my personal Santa Claus :smiley:
How may I download this? It’s not available on brasil App Store…
Which TV model? You can try switching country to get access to other apps (and switch back after installing).
See https://youtu.be/4U87VZ1dyLo
Anything in the works to get subtitles displayed without transcoding in 4k?
Works fine in 4k if you’re using external SRT subtitles, no transcoding required.
Some kind of progress report …
After Ive started video player testing on real TV Ive discovered some issues with video playback.
Sometimes video playback has different behavior on real TV and webOS emulator and I dont fully understand this thing from LG.
Some tech issued that were discovered after testing on real TV
  1. Video playback can stop playback after start after 1-2-3-4-5-6 and etc seconds
  2. Sometime system embedded video player reports that it started to the app but actually it freezes playback … no playback. Just shows a static frame from video content.
  3. Video content can not be scaled on real TV (despite it can be done on webOS emulator)
So … the first two items from issues list (1 and 2) were finally fixed or at least I can not catch them while testing playback. The last one (3) will not be implemented … it means that ppl who would like to be able to choose to watch video with black bars but keeps video aspect ration or watch video stretching video content to full screen will not be possible. LG takes video size handling by own algorithm and will use video content meta data.
Algorithm that decide to transcode or not video content when user select audio or subtitles track was improved (especially for subtitles tracks). Unfortunately audio track selecting (in direct play mode) will still relay on audio track index and match this track index to information from PMS and sometime can lead to incorrect audio track selecting. Unfortunately LG does not share enough information (like track language and etc) about audio tracks to make correct match.
Video content seeking will restart video player less (in transcoding mode).
Maybe there are some other changes that I can not remember now.
PS
The main problem is that LG webOS emulator does not work the same way as real TV.
More or less webOS 1.x works stable.
webOS 2.x emulator uauly does not work well and after installing it, it works only several times and usually breaks it self and I can not test the app on it.
webOS 3.x emulator quite well but does not store settings and after restart I have to relink Plex account. Usually does not show video content picture … I can see only black or usually white background but I can hear audio track
@bublikoff
does 4K HDR x265 working with Xplay? will try it with OLED 2017 TV’s.
also, does ATMOS work?
Thanks it’s indeed working with SRT. Couldn’t ask for more from this app.
Is it possible to direct play video but transcode DTS audio to DD5.1? Currently I convert each file with DTS manually, but it would be nice to skip this step. My Sonos doesn’t support DTS so if I don’t convert the file I get no audio.
Hmm okay i found out that the sound problem with Dobly digital is that Vikings is EAC3. It this gonna bee supported? :slight_smile:
Thanks for the work!
I dicovered missing DTS and DolbyDigital signs in XPlay using PMS ver 1.10.1.4602.
DTS
No sign, if audio is „pure“ DTS 5.1 or DTS 2.0
Is sign, if audio is DTS-MA 5.1 or DTS-MA 7.1 etc
AC3
No sign, if audio is AC3 5.1 or AC3 2.0
Is sign, if audio is extended EAC3 5.1 or EAC3 2.0
Maybe the problem is on the server side, but can anyone confirm it?
Is it possible to use the plex iphone appa as remote control for the XPlay app on LG oled tv?
Hi I didn’t get sound when playing a truehd atmos 7.1 file. Converted to AC3 to fix it. Is it possible to add trueHD support? I got a LG with WebOS 3.5
I just bought this app on my Oled television on WebOS 3.5, and really love it. It works flawlessly playing 4k HDR files. Thanks for this great software!
