@Mosdn85 said:
Hi,Why the playback option works on some movies or tv shows in Xplay? It start always in the beginning.
But in Plex it works perfectly.grtzzzz
Lack of information
Need more detailed information about situations
Lack of information
@z1z said:
bublik, is there any way to install the newest version of xplay on webos2.0 ? or is it only for webos3.5x?
Which one is the newest version? If you are speaking about participating in tests of devel version … just email me your user id
Is it not possible to add the rating of the films in number? for example 7.5 …
do i have to pay for every TV for XPLAY or just once for the Server with USER ID ?
User id is just internal Plex account id … everywhere you will use the activated or paid account or whatever you call it demo limits will be removed … in case you will switch differ Plex account demo limits will be restored. just get back to activated account. TV amount is not are not limited
thanks a million
Can you explain what for? what it will change in your life?
Will it matter for you to see 7.5 instead of 3 of 5 stars?
another question please
I have LG webos3.5 on my LG C7 OLED with XPLAY along with PLEX both access plex media server on MY Synology NAS
XPLAY plays subtitles great without transcoding which plex client fails
howerver i was trying 4K GODs of Egypt 4K—HEVC on XPLAY it did not play and gave me an error not supported format although the same Movie is playing on PLEX client no problem without transcoding i even tried to activate transcoding on XPLAY it wouldn’t play the file at all (Gods.of.Egypt.2016.2160p.BluRay.REMUX.HEVC.DTS-X.7.1-FGT)
i tried another 4k file LOGAN and it is working fine with subtitles although it is the same 4K -Hevc but audio is not DTS
what am i doing wrong here thanks
For the moment I don’t have the answer. I do have some ideas … but I need to collect more information … more sample videos.
As for eg … for the moment I do test new version and tried one new movies … and I was surprised that it plays well video stream but audio keeps silent and it was webOS 3.x
So Ive tried to play the same media on webOS 1.x and … everything played well … no audio issue.
What the difference between webOS 1.x and webOS 3.x I was always thought that newer is better … but is this valid for all situations?!
thanks a million bublikoff yes its not valid probably a bug or something i just watched bbc planet earth II and it played flawlessly 4k HDR (i think the problem with the Gods of Egypt is in audio which is DTS x 7.1 with XPLAY but I’m just guessing )
I know this is out of context is it possible to have XPLAY on POPCORN MEDIA Like VTEN or A400 …etc?
I will but XPLAY def for my PLEX media Server u did great work thanks
Where can I disable autoplay to the next video or episode on xplay?
The version of xplay I have is: 20180322.1.2.8
Hello! I’d like to force the audio on the ARC output only when I’m using plex or xplay. I’m not interested to use my AV ampli for normal tv. Is there the possibility to do that?
There is no such ability on webOS TV … at least for HTML based apps
@KJ31 said:
Where can I disable autoplay to the next video or episode on xplay?The version of xplay I have is: 20180322.1.2.8
Next version will allow to force ask for next episode or play it automatically
Its better to ask here about android version.
https://forums.plex.tv/discussion/292731/xplay-android#latest
Hi bublikoff,
I own an oled C7V with the latest webos and I am interested in testing your application and giving you back feedback so we can make it perfect!
I mainly use direct play , because my plex server is on a windows stick. Everything plays like a charm untill now.
Is there a way we can watch a trailer for each movie? Also, as proposed above, rating from 1 to 10 would be preferred. For example, I only watch movies with rating > 7 (although I may have already downloaded it for image and sound check)
Thanks,
Harris
Upcoming version will allow to setup auto playback for movie trailer
Still don’t fully understand what the difference between 3 (and more) of 5 stars and rating > 7.
Of course I also don’t like to watch not interesting movies … and if I see less than 3 stars i just don’t watch it …
Upcoming version will allow to setup auto playback for movie trailerAlso, as proposed above, rating from 1 to 10 would be preferred. For example, I only watch movies with rating > 7 (although I may have already downloaded it for image and sound check)
Using 1 to 5 rating would lead me to watch either bad movies (rating 3 is lower than 7) or miss a good movie (rating 4 is actually 8, which is way more than 7). Of course this means, you have access to the real rating based to 1-10 system, not just multiply 1-5 by 2…
Thank you for the reply and look forward to the next version, do you know when that will be released?
I hope to release it in coming April with basic functionality.
You can join and also test devel version … just email me your user id
