XPlay (WebOS)
@bublikoff : I could offer you to make German translation. Just one question: I see the file is UTF-8, that, means it´s no problem using German special chars like üöäß ?
Markus
How come Netflix does Dolby Digital Plus but xplay only Dolby digital normal? I’m playing a movie with Atmos.
Probably because your content doesn’t have compressed (lossy) Dolby Digital Plus (Atmos), and Netflix does. Compressed DD+ Atmos is not the same as TrueHD (lossless) Atmos seen in UHD Blurays for instance, so the content has to support this. Netflix does, most rips don’t. You can only get compressed lossy Atmos over HDMI ARC.
So yeah, it’s pretty confusing when Atmos can mean 2 versions of Atmos… But doesn’t have anything to do with XPlay.
That’s a bummer so I’d have to compress the audio track on my content myself if thats even possible. I don’t want to get Apple TV 4k just to play Atmos content, because I like the seemless interaction between webos and xplay. Xplay works really good but yeah its too bad current hdmi spec doesn’t support lossless Atmos.
Yes, UTF8 supports uöäß…
br
I stille miss that i can use play/pause on my LG remote :slight_smile:i have send a email with some things but no answer?
How do you download the new version and test on my LG. I have the original version currently. Thx
Ah sorry! It works now! Nice! I really like the new version. But isent the “old” version faster?
It depends where you feel that it slower … need more information. I can not measure UI speed =)) I can only rely on my feelings. New version will work faster for eg with big libs … it will open big lib faster … and etc … you can switch off media art to speed up details screen
Still need at least French and German language. The rest will be omitted as it will take too much time to wait help in translation
Will the new UI support collections?
If so, will there be a view filter where individual movies are not shown but their collections are? For instance, I have a Disney collections with a dozen movies. Those movies are not shown in the list but Disney is, and I can drill into it to see all those movies.
Okay thanks. I will try to make some tests :slight_smile:
Meaby i can help with a Danish translation?
Any help? Still won’t work, but the Plex app works just fine. XPlay works no problem on my other TV.
-Dan V.
please can you describes you HW running Plex Server?
@bublikoff
Any way new client aims to have cleaner UI … less elements on the screen
One thing i love about the current XPlay UI is the ‘breadcrumb bar’ on the top that allows me to easily ‘jump up’ when navigating. It’s something missing in the normal plex app that is super annoying.
Will that same ‘breadcrumb bar’ be available in the new version of xplay. I really really really hope it will :slight_smile:
Thanks!
could be translating to Portuguese-BR, but I do not know how to do it.
could you guide me?
I’ve updated the german translation by vistalba so it’s mostly complete now. Since I’m not firm with github I leave it here. de.zip (3.5 KB)
Did anybody solve the stretching of video issue? Currently have that on my 4:3 content. Works well in official app but on Xplay the image is stretched.
Hello.
This is the Italian translation:
it.zip (11.0 KB)
Ciao!
Thx. Anyway it seams that it has some encoding problem … could you check it and email me?
2018-07-18_034906
