XPlay (WebOS)
Have added media version selection. Use “more actions” (three dots) button → Media
Done. Make sure that you have restarted the app. And it will start online version only in case you have good Internet connection while the app is starting. In case it started original version just close the app from recent apps list and try to start it again
I’m stuck on version v2.714.091…I would really appreciate the update when you have the time.
User 15168687-GB
Thanks for all you’re hard work.
Hey - if it is alright to jump aboard this train would you mind pushing it to;
6327179-GB
Many thanks,
Wayne
Thanks for quickly working on that.
Just gone to give it a go and my version number is now 2.715.521. So older than the pervious version??? Now when selecting certain films I get ‘Aw, Snap! Something went wrong…’ Any ideas?
The new version does not work.
It shows Xplay with a spinning round and nothing else.
I try everything, nothing to do …
I can not reach the user selection screen …
Please push update for me too : 1529737-RO
Geez what a mess Why is @LG so non cooperative? @bublikoff
@bublikoff
I can not run my videos.
I have already restarted the application, but it does not work. continues to give this error message.
demonstration of the problem of version 2.715.521:
I can run my videos normally through official PLEX, but in XPLAY I’m having these errors.
VASCO
Looks like its something to do with 4k videos as it works fine for 1080p
@bublikoff @SteFlix
Yes, in 1080p sources is working correctly!
VASCO
I’m also on 2.714.091, could you also the push update to 539116-NL?
@bublikoff I still don’t get why even with the new version pushed, resume not working properly. For example I was watching a show and turned off TV at 20m30s and it wants to resume at 7m04s???
Ver: 2.715.521 LG Webos 2
Yeah, I also have problem with loading 4K videos, 1080p is OK.
@bublikoff can you please add me to the latest version. User ID: 5582058-AU
Once again i cannot log-in and link, ETA on fix?
Same with 2.175.521…
very very very catastrophic… :triumph:
Since nothing works and apparently we are taken for beta testers, I request the refund of the application.
It’s shameful to offer such rotten apps …
I can’t login either since yesterday. Seems to be a weekly issue. Refund or rollback until all issue fixed!
And the 4K media cannot load… Why don’t you make an option to disable online updates?
Fully agree !!!
I have the solution !!
I bought a Xiaomi Mi box 3 for 45 € and I put the xplay app for android which is much more accomplished than this rot on webos …
The developer must have relationships with Microsoft to lay versions that are not even in beta! they are at the Alpha stage !!!
When we create applications, we put them on sale, we make sure before there is any problem! As for Xplay for WebOS, it’s theft !!! quite simply !
