Server Version#: 1.40.5.8897
Player Version#:Irrelevant
Is it possible to manually fix missing files similar to xxxx.so stat: No such file or directory?
Using htop or lsof -p 7743, I can see a snapshot of files open in process with PID 7743, and many missing files are visible there.
Although the server is running perfectly fine, I still want to ask if there is any solution to address these missing files.
Here are the outputs:
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
Plex 7743 root cwd DIR 0,132 4096 25061262 /run/s6-rc:s6-rc-init:pEEeNa/servicedirs/svc-plex
Plex 7743 root rtd DIR 0,132 4096 25061046 /
Plex 7743 root txt REG 0,132 20959808 43007909 /usr/lib/plexmediaserver/Plex Media Server
Plex 7743 root mem-r REG 8,2 17170444 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-shm (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486240 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/librv30_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15491570 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libh264_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486164 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libvp9_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486239 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libaac_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486238 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/librv40_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486237 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libmpeg2video_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486236 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libmp3_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466509 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libvc1_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486235 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libwmv3_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486234 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libmpeg1video_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466508 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libhevc_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486231 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/liblibx264_encoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486233 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libcook_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15486232 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libflv_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15467368 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libac3_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15467067 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libmpeg4_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15467068 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libaac_encoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466960 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libwmv2_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15467367 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libsvq3_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466959 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libmp2_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466571 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libdca_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466507 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libpcm_bluray_decoder.so (stat: No such file or directory)
Plex 7743 root mem REG 8,2 15466570 /config/Library/Application Support/Plex Media Server/Codecs/b8ae7ab-cd9c26e1cae8f48631565a53-linux-x86_64/libmsmpeg4v3_decoder.so (stat: No such file or directory)
Plex 7743 root mem-r REG 8,2 17170446 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-shm (stat: No such file or directory)
Plex 7743 root DEL REG 0,431 2 /dev/shm/tmp-796197301
Plex 7743 root mem REG 0,132 43010594 /usr/lib/plexmediaserver/lib/libpciaccess.so.0 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010605 /usr/lib/plexmediaserver/lib/libva-drm.so.2 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010606 /usr/lib/plexmediaserver/lib/libva.so.2 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010588 /usr/lib/plexmediaserver/lib/libnghttp2.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010584 /usr/lib/plexmediaserver/lib/libicuioplex.so.69 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010582 /usr/lib/plexmediaserver/lib/libicudataplex.so.69 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010569 /usr/lib/plexmediaserver/lib/libcharset.so.1 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010564 /usr/lib/plexmediaserver/lib/libboost_system.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010563 /usr/lib/plexmediaserver/lib/libboost_regex.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010562 /usr/lib/plexmediaserver/lib/libboost_random.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010561 /usr/lib/plexmediaserver/lib/libboost_program_options.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010556 /usr/lib/plexmediaserver/lib/libboost_date_time.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010554 /usr/lib/plexmediaserver/lib/libboost_atomic.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010579 /usr/lib/plexmediaserver/lib/libgcompat.so.0 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010567 /usr/lib/plexmediaserver/lib/libc++.so.2 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010576 /usr/lib/plexmediaserver/lib/libeditline.so.1 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010596 /usr/lib/plexmediaserver/lib/libpython27.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010570 /usr/lib/plexmediaserver/lib/libcrypto.so.3 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010600 /usr/lib/plexmediaserver/lib/libssl.so.3 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010599 /usr/lib/plexmediaserver/lib/libsqlite3.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010585 /usr/lib/plexmediaserver/lib/libicuucplex.so.69 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010583 /usr/lib/plexmediaserver/lib/libicui18nplex.so.69 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010581 /usr/lib/plexmediaserver/lib/libiconv.so.2 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010566 /usr/lib/plexmediaserver/lib/libboost_timer.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010565 /usr/lib/plexmediaserver/lib/libboost_thread.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010560 /usr/lib/plexmediaserver/lib/libboost_locale.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010559 /usr/lib/plexmediaserver/lib/libboost_json.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010558 /usr/lib/plexmediaserver/lib/libboost_iostreams.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010557 /usr/lib/plexmediaserver/lib/libboost_filesystem.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010555 /usr/lib/plexmediaserver/lib/libboost_chrono.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010580 /usr/lib/plexmediaserver/lib/libhdhomerun.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010587 /usr/lib/plexmediaserver/lib/libminiupnpc.so.17 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010572 /usr/lib/plexmediaserver/lib/libdrm.so.2 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010601 /usr/lib/plexmediaserver/lib/libswresample.so.4 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010602 /usr/lib/plexmediaserver/lib/libswscale.so.6 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010553 /usr/lib/plexmediaserver/lib/libavutil.so.57 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010552 /usr/lib/plexmediaserver/lib/libavformat.so.59 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010550 /usr/lib/plexmediaserver/lib/libavcodec.so.59 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010577 /usr/lib/plexmediaserver/lib/libfmt.so.8 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010603 /usr/lib/plexmediaserver/lib/libtag.so.1 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010593 /usr/lib/plexmediaserver/lib/libopencv_imgproc.so.405 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010592 /usr/lib/plexmediaserver/lib/libopencv_imgcodecs.so.405 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010590 /usr/lib/plexmediaserver/lib/libopencv_core.so.405 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010578 /usr/lib/plexmediaserver/lib/libfreeimage.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010571 /usr/lib/plexmediaserver/lib/libcurl.so.4 (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010598 /usr/lib/plexmediaserver/lib/libsoci_sqlite3.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010597 /usr/lib/plexmediaserver/lib/libsoci_core.so (stat: No such file or directory)
Plex 7743 root mem REG 0,132 43010549 /usr/lib/plexmediaserver/lib/ld-musl-x86_64.so.1 (stat: No such file or directory)
Plex 7743 root 0r CHR 1,3 0t0 5 /dev/null
Plex 7743 root 1w FIFO 0,14 0t0 37960 pipe
Plex 7743 root 2w FIFO 0,14 0t0 37961 pipe
Plex 7743 root 3u a_inode 0,15 0 2086 [eventfd:409]
Plex 7743 root 4u a_inode 0,15 0 2086 [eventpoll:3]
Plex 7743 root 5u a_inode 0,15 0 2086 [eventfd:410]
Plex 7743 root 6u a_inode 0,15 0 2086 [eventpoll:5]
Plex 7743 root 7w REG 8,2 9357124 14811385 /config/Library/Application Support/Plex Media Server/Logs/Plex Media Server.log
Plex 7743 root 8ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 9u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 10ur REG 8,2 65536 17170444 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-shm
Plex 7743 root 11ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 12u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 13ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 14u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 15ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 16u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 17ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 18u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 19ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 20u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 21ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 22u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 23ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 24u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 25ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 26u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 27ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 28u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 29ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 30u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 31ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 32u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 33ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 34u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 35ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 36u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 37ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 38u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 39ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 40u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 41ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 42u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 43ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 44u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 45ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 46u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 47ur REG 8,2 1910026240 17191709 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db
Plex 7743 root 48u REG 8,2 7257432 17170443 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal
Plex 7743 root 49u a_inode 0,15 0 2086 [eventfd:24]
Plex 7743 root 50u a_inode 0,15 0 2086 [eventpoll:49,51,52,53,61,68,72,79,81]
Plex 7743 root 51u sock 0,8 0t0 32239 protocol: TCPv6
Plex 7743 root 52u sock 0,8 0t0 32241 protocol: TCP
Plex 7743 root 53u sock 0,8 0t0 4657862 protocol: TCP
Plex 7743 root 54ur REG 8,2 357376 17191861 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db
Plex 7743 root 55u REG 8,2 0 17170445 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
Plex 7743 root 56ur REG 8,2 32768 17170446 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-shm
Plex 7743 root 57ur REG 8,2 357376 17191861 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db
Plex 7743 root 58u REG 8,2 0 17170445 /config/Library/Application Support/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.blobs.db-wal
Plex 7743 root 59u sock 0,8 0t0 50383 protocol: UNIX-STREAM
Plex 7743 root 60u sock 0,8 0t0 50384 protocol: UNIX-STREAM
Plex 7743 root 61u sock 0,8 0t0 6312046 protocol: TCPv6
Plex 7743 root 62u sock 0,8 0t0 6308179 protocol: TCP
Plex 7743 root 63r FIFO 0,14 0t0 47804 pipe
Plex 7743 root 64r FIFO 0,14 0t0 6301795 pipe
Plex 7743 root 65u sock 0,8 0t0 6306584 protocol: TCP
Plex 7743 root 66u sock 0,8 0t0 6298004 protocol: TCP
Plex 7743 root 67r FIFO 0,14 0t0 3555573 pipe
Plex 7743 root 68u sock 0,8 0t0 6312068 protocol: TCPv6
Plex 7743 root 69w FIFO 0,14 0t0 47805 pipe
Plex 7743 root 70u sock 0,8 0t0 6295257 protocol: TCP
Plex 7743 root 71u sock 0,8 0t0 6307443 protocol: TCP
Plex 7743 root 72u sock 0,8 0t0 6310108 protocol: TCPv6
Plex 7743 root 73u sock 0,8 0t0 40888 protocol: NETLINK
Plex 7743 root 74u a_inode 0,15 0 2086 [eventfd:424]
Plex 7743 root 75u a_inode 0,15 0 2086 [eventpoll:74,76,77]
Plex 7743 root 76u sock 0,8 0t0 40889 protocol: UDP
Plex 7743 root 77u sock 0,8 0t0 40890 protocol: UDP
Plex 7743 root 78r FIFO 0,14 0t0 3549656 pipe
Plex 7743 root 79u sock 0,8 0t0 6253893 protocol: TCPv6
Plex 7743 root 80u sock 0,8 0t0 6277161 protocol: TCP
Plex 7743 root 81u sock 0,8 0t0 6074593 protocol: TCPv6
Plex 7743 root 82w FIFO 0,14 0t0 3549657 pipe
Plex 7743 root 85u sock 0,8 0t0 6295256 protocol: TCP
Plex 7743 root 87w FIFO 0,14 0t0 3555574 pipe
Plex 7743 root 97u sock 0,8 0t0 5656923 protocol: TCP
root@3aed4375dcb3:/usr/lib/plexmediaserver# ll
total 37872
drwxr-xr-x 5 root root 4096 Aug 21 22:35 ./
drwxr-xr-x 1 root root 4096 Aug 21 22:35 ../
-rwxrwxr-x 1 root root 1549208 Aug 20 21:47 CrashUploader*
drwxrwxr-x 2 root root 4096 Aug 21 22:35 etc/
drwxrwxr-x 2 root root 4096 Aug 21 22:35 lib/
-rwxr-xr-x 1 root root 276984 Aug 20 21:26 'Plex Commercial Skipper'*
-rwxrwxr-x 1 root root 3390536 Aug 20 21:47 'Plex DLNA Server'*
-rwxr-xr-x 1 root root 119328 Aug 20 21:26 'Plex Media Fingerprinter'*
-rwxrwxr-x 1 root root 5569256 Aug 20 21:47 'Plex Media Scanner'*
-rwxrwxr-x 1 root root 20959808 Aug 20 21:47 'Plex Media Server'*
-rwxr-xr-x 1 root root 3408944 Aug 20 21:26 'Plex Relay'*
-rwxr-xr-x 1 root root 11048 Aug 20 21:26 'Plex Script Host'*
-rwxrwxr-x 1 root root 11168 Aug 20 21:47 'Plex SQLite'*
-rwxr-xr-x 1 root root 332136 Aug 20 21:26 'Plex Transcoder'*
-rwxr-xr-x 1 root root 3104984 Aug 20 21:26 'Plex Tuner Service'*
drwxrwxr-x 11 root root 4096 Aug 21 22:35 Resources/
root@3aed4375dcb3:/usr/lib/plexmediaserver# ll lib/
total 85076
drwxrwxr-x 2 root root 4096 Aug 21 22:35 ./
drwxr-xr-x 5 root root 4096 Aug 21 22:35 ../
-rwxr-xr-x 1 root root 747264 Aug 20 21:26 ld-musl-x86_64.so.1*
-rwxr-xr-x 1 root root 5985408 Aug 20 21:26 libavcodec.so.59*
-rwxr-xr-x 1 root root 6536904 Aug 20 21:26 libavfilter.so.8*
-rwxr-xr-x 1 root root 3160360 Aug 20 21:26 libavformat.so.59*
-rwxr-xr-x 1 root root 920848 Aug 20 21:26 libavutil.so.57*
-rwxr-xr-x 1 root root 10584 Aug 20 21:26 libboost_atomic.so*
-rwxr-xr-x 1 root root 33040 Aug 20 21:26 libboost_chrono.so*
-rwxr-xr-x 1 root root 4728 Aug 20 21:26 libboost_date_time.so*
-rwxr-xr-x 1 root root 130952 Aug 20 21:26 libboost_filesystem.so*
-rwxr-xr-x 1 root root 196240 Aug 20 21:26 libboost_iostreams.so*
-rwxr-xr-x 1 root root 265640 Aug 20 21:26 libboost_json.so*
-rwxr-xr-x 1 root root 469992 Aug 20 21:26 libboost_locale.so*
-rwxr-xr-x 1 root root 322992 Aug 20 21:26 libboost_program_options.so*
-rwxr-xr-x 1 root root 26848 Aug 20 21:26 libboost_random.so*
-rwxr-xr-x 1 root root 195256 Aug 20 21:26 libboost_regex.so*
-rwxr-xr-x 1 root root 4696 Aug 20 21:26 libboost_system.so*
-rwxr-xr-x 1 root root 113232 Aug 20 21:26 libboost_thread.so*
-rwxr-xr-x 1 root root 30768 Aug 20 21:26 libboost_timer.so*
-rwxr-xr-x 1 root root 5064 Aug 20 21:26 libcharset.so.1*
-rwxr-xr-x 1 root root 4990824 Aug 20 21:26 libcrypto.so.3*
-rwxr-xr-x 1 root root 747264 Aug 20 21:26 libc.so*
-rw-r--r-- 1 root root 1152880 Aug 20 21:26 libc++.so.2
-rwxr-xr-x 1 root root 519808 Aug 20 21:26 libcurl.so.4*
-rwxr-xr-x 1 root root 41616 Aug 20 21:26 libdrm_amdgpu.so.1*
-rwxr-xr-x 1 root root 135336 Aug 20 21:26 libdrm_intel.so.1*
-rwxr-xr-x 1 root root 39328 Aug 20 21:26 libdrm_radeon.so.1*
-rwxr-xr-x 1 root root 84640 Aug 20 21:26 libdrm.so.2*
-rwxr-xr-x 1 root root 39336 Aug 20 21:26 libeditline.so.1*
-rw-r--r-- 1 root root 94032 Aug 20 21:26 libfmt.so.8
-rwxr-xr-x 1 root root 5431192 Aug 20 21:26 libfreeimage.so*
-rwxr-xr-x 1 root root 58688 Aug 20 21:26 libgcompat.so.0*
-rwxr-xr-x 1 root root 88336 Aug 20 21:26 libhdhomerun.so*
-rwxr-xr-x 1 root root 918840 Aug 20 21:26 libiconv.so.2*
-rwxr-xr-x 1 root root 11037416 Aug 20 21:26 libicudataplex.so.69*
-rwxr-xr-x 1 root root 3670008 Aug 20 21:26 libicui18nplex.so.69*
-rwxr-xr-x 1 root root 59936 Aug 20 21:26 libicuioplex.so.69*
-rwxr-xr-x 1 root root 2110104 Aug 20 21:26 libicuucplex.so.69*
-rw-r--r-- 1 root root 668760 Aug 20 21:26 libigdgmm.so.12
-rwxr-xr-x 1 root root 57592 Aug 20 21:26 libminiupnpc.so.17*
-rw-r--r-- 1 root root 149272 Aug 20 21:26 libnghttp2.so
-rwxr-xr-x 1 root root 14941184 Aug 20 21:26 libonnxruntime.so.1.16.3*
-rwxr-xr-x 1 root root 2588472 Aug 20 21:26 libopencv_core.so.405*
-rwxr-xr-x 1 root root 3263576 Aug 20 21:26 libopencv_dnn.so.405*
-rwxr-xr-x 1 root root 915080 Aug 20 21:26 libopencv_imgcodecs.so.405*
-rwxr-xr-x 1 root root 3789320 Aug 20 21:26 libopencv_imgproc.so.405*
-rwxr-xr-x 1 root root 36984 Aug 20 21:26 libpciaccess.so.0*
-rw-r--r-- 1 root root 1218552 Aug 20 21:26 libpion.so
-rwxr-xr-x 1 root root 4598816 Aug 20 21:26 libpython27.so*
-rwxr-xr-x 1 root root 223592 Aug 20 21:26 libsoci_core.so*
-rwxr-xr-x 1 root root 88024 Aug 20 21:26 libsoci_sqlite3.so*
-rwxr-xr-x 1 root root 982000 Aug 20 21:26 libsqlite3.so*
-rwxr-xr-x 1 root root 641976 Aug 20 21:26 libssl.so.3*
-rwxr-xr-x 1 root root 154400 Aug 20 21:26 libswresample.so.4*
-rwxr-xr-x 1 root root 857800 Aug 20 21:26 libswscale.so.6*
-rwxr-xr-x 1 root root 1157344 Aug 20 21:26 libtag.so.1*
-rwxr-xr-x 1 root root 87456 Aug 20 21:26 libusb-1.0.so.0*
-rwxr-xr-x 1 root root 9488 Aug 20 21:26 libva-drm.so.2*
-rwxr-xr-x 1 root root 173160 Aug 20 21:26 libva.so.2*
-rw-rw-r-- 1 root root 920 Aug 20 23:07 plexmediaserver.default
-rwxrwxr-x 1 root root 6669 Aug 20 23:07 plexmediaserver.init*
-rw-rw-r-- 1 root root 1664 Aug 20 23:07 plexmediaserver.service
