Yahoo Movies Metadata Agent
This is a Metadata Agent for Yahoo Movies. It can be used as a single primary metadata agent, or work as a secondary agent for Freebase. This Agent collects English data: title, year, summary, content rating (MPAA), duration, genres1, originally available, studio, country, rating, director, cast and poster(s).
Source: https://github.com/sander1/Yahoo-Movies.bundle
Update 30 Jan, 2013
  • FIX: The agent will now grab all paragraphs from the summary text (instead of only the first one).
Update 6 Feb, 2013
  • FIX: Try 'In Theaters' year before year from the title. Fallback to year given to us by the scanner.
Installation
  • Unzip Yahoo-Movies.zip, this gives you a file/folder with the name Yahoo-Movies.bundle
    • Mac
      • Move Yahoo-Movies.bundle to ~/Library/Application Support/Plex Media Server/Plug-ins. The easiest way to find this folder is to use the Go to folder... option in the Go menu of the Finder.
        ~ is your home folder. If you can't find your Library folder, have a look at [OS X Lion: Where did my Library go?](http://reviews.cnet.com/8301-13727_7-20082044-263/os-x-lion-where-did-my-library-go/)
    • Windows
      • Move Yahoo-Movies.bundle to the Plug-ins folder: right-click the Plex Media Server icon in the system tray and open the Plug-ins folder
    • Linux (Ubuntu)
      • Move Yahoo-Movies.bundle to /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins
      • cd "/var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Plug-ins"
      • sudo chown -R plex:plex Yahoo-Movies.bundle
  • Restart Plex Media Server
    On Mac and Windows: just quit and start again
    On Linux (Ubuntu): sudo service plexmediaserver restart
  • Open Plex/Web (sometimes still named "Media Manager") and go to Settings. Go to Agents and select Movies. You can use Yahoo Movies as a primary agent...
    ...or add it as a secondary agent to the list under Freebase:
1 Genres are limited to: Action, Adventure, Animated, Comedy, Crime, Drama, Family, Fantasy, Foreign, Horror, Musical, Romance, Sci-Fi, Thriller, War
Hi, curious does this agent still work? I've implemented it but it doesn't appear to be generating any data. thanks
This agent still work?
No, unfortunately it’s completely broken. Yahoo no longer publishes descriptions about movies, just trailers :frowning:
