Important: As announced since months, dropped legacy API mode. If you have any plugin issues, be sure to update them. If you use manual API, see Wiki for how to do things now.
Note: Android 12 broke volume buttons outside of application. (Sign in - Google Accounts) there’s no possible workarounds until they fix it.
Many tweaks to Android Auto. Support shuffle / repeat mode, better UI navigation pattern, …
Another rounds of Jellyfin API bugs workarounds.
Many many other things that can’t fit here.
Do not forget to rate the application.
If you like this, please buy the Unlocker / Donate to ensure continued development.
IMPORTANT: Finally making the final jump to target Android 12 with the many impacts. Hopefully all the preparation was enough, but if you have issues on Android 12 please contact support with details.
Note: This now open the way to support Material YOU themes. Please show interest on the forum about that or not.
Note: Many external libraries updates, as always contact support if any issues.
Fixed: Try to fix status bar overlap on some devices.
Fixed: Fix HTTPS connection from wizard in some cases like non standard proxy configuration.
Fixed: Many small fixes backported from Symfonium.
Some other reported issues and always more optimizations.
IMPORTANT: This is a major version, with design changes, targeting Android 13 and requiring Android 6+
Yatse now requires at least Android 6. Previous versions will continue to work on your older devices without any issues.
Long overdue major design update, complete tuning of every UI details while keeping the same UX to reduce the flow of insults from last large update:
The updated themes, and added support of Material you, requires removal of most of the current media center accent color. Please contact support with details about why you’d absolutely need this.
The themes are now based on Material design 3, you can use Google theme generator to propose new themes for integration in Yatse.
The icon font for custom commands have been updated for consistency, you may have to update your defined icons.
Targeting Android 13 with the associated changes when using it:
OS level language configuration.
Themed icon.
New permissions for local device files.
Updated notification handling.
Added: Support for Material you themes. (Android 12+)
Added: Setting option to disable image rounding.
Changed: Many external libraries updates, as always contact support if any issues…
Fixed: Single season download.
Fixed: Possible UPnP issues when casting images
Fixed: Number pad dialog properly vibrate according to settings.
Fixed: A few rare crashes. Remember that it’s way easier if you contact support when you have crashes than trying to guess from the little data that is sometimes available in Google Play Console.
Fixed: Long press shows/seasons then offline actions not working under some conditions.
Fixed: Local audio player support more ogg files + more resilient to some bad FLAC files.
Fixed: Wokaround VLC streaming on Android 13 (Will still lack resume point update until changes is made on their side)
Note: It’s written in small usually, but as a small reminder, optional donations are always welcome to help this project keeping up (Best on https://ko-fi.com/tolriq). Single time purchase and no ads for 12 years now is not really sustainable.
Changed: Compiled for and targeting Android 14. Please report any issues if you are using Android 14 beta.
Changed: Updated a lot of things for Android 14 that might impact other versions. Please report any issue you might have, specially on themes and colors.
Note: Google no more allows Wallpaper backup on Android 14.
Fixed: Sometimes provider sync starts before offline action are pushed resulting in data loss.
