Changed: Many internal changes and library updates to prepare for Android 11.
Added: Paste dialog (Long press keyboard button in remote screens) now allow sending of direct url for playback + added paste dialog custom command to increase discoverability.
Added: New option to not use BubbleUPnP when streaming to local device.
Added: New option to not sort PVR channel groups for channels filtering.
Changed: Use different overlay icons to indicate partial offline status.
Fixed: Possible wrong player used from voice assistant (Google Home/Alexa/…) integration plugin.
Fixed: Jellyfin wrongly marking streamed media as played when it’s not the case.
Fixed: Some issues when importing exported playlists on other devices.
Fixed: Try to workaround some devices issues reporting wrong connection status.
Fixed: CPU usage after showing the now playing playlist.
Fixed: Possible offline status issues after partial Tv Show sync.
Fixed: Search when using both group by set and hide single video sets.
Fixed: Some other reported issues and always more optimizations.
Do not forget to rate the application.
If you like this, please buy the Unlocker / Donate to ensure continued development.
Changed: Another big round of internal changes to improve performance and workaround Android Q/R bugs. Please report issues to support as usual.
Changed: Removed option for now playing bar to hide on scrolling as there was many edge cases where it was impossible to bring it back without changing screen.
Fixed: Removed option for now playing bar to hide on scrolling as there was many edge cases where it was impossible to bring it back without changing screen.
Fixed: Slow casting of images when using Yatse addon.
Fixed: Sometimes when starting a new song during cast the new song started at previous media position.
Fixed: Improvements to AI voice commands handling to match media with similar names. Remember to contact support when the commands are badly understood to help training the AI.
Fixed: Small UI details for Android 11.
Fixed: Startup page sometimes not working.
Hi all I’d like to share some issues I’m having with Android Auto.
I’m on a OP 8T with Android 11 and Yatse 10.4.5b.
The graphic progress indicator is not smooth and there is the strange behaviour when I go to the next song. I can’t check numbers because they are not displayed.
Sometimes also the graphic indicator does not work or even worse it does not switch from play icon to pause. When music is playing it shows play icon till when I touch it, then the music keep going and icon shows correctly the pause icon. When this happen the numbers and the round graphic indicator updates.
With Android 11 the phone version of AA works pefectly, the issue exists when I use AA on car screen.
I’ve already removed Yatse from battery optimisation.
Added: Track selection support for Plex, Emby and Jellyfin when casting and transcoding. (There’s probably many edge cases where selection does not work yet, please contact support with logs for fixes)
Added: Transcode for downloads and smart downloads for Plex, Emby, Jellyfin and Kodi via BubbleUPnP.
Added: Tasker plugin screen selection support now playing screen.
Fixed: Chromecast selection from voice commands.
Fixed: Wrong song playing when starting a playlist in local player and something was already playing.
Fixed: Properly update host lists when host is changed outside of main UI.
Fixed: Streaming from Emby when behind a reverse proxy.
Added: New option to have any drawer always opened in landscape (left and/or right). Previous settings is not migrated to help discover the new options, you’ll need to select again left if you used static left drawer.
Added: New way to discover and reconnect to Kodi when host change IP and Zeroconf is not working/configured.
Added: Support for differential music sync for Kodi 19 (Require Kodi 19 Beta 1 at least).
Added: Support swiping left/right in now playing screen to change tracks (next/previous).
Added: Smart filters and FAB to Music Videos.
Fixed: Start page not working when configured to Addons.
Fixed: Handling of special seasons in Emby/Jellyfin.
Fixed: Resume point / play count not updated when playing offline cached media with Mx Player.
Hi, I bought the premium for Plex support. My server is hosted on Synology and I’m able to see the server in the list on the same network. So IP and Port are auto populated. But keying in my Plex email and password does not work. I have 2FA setup on my Plex account. Some help please
you can still sign in via 2FA. Specifically, you append a valid verification code to the end of the password when submitting: <password><verification code>
For instance, imagine that your password is “secret” (please, please use a strong, unique password) and that you check your authenticator app and receive the verification code “123456”. You would then submit secret123456 as the password.
Ahh ok thank you so much!! I’ve managed to connect successfully but it’s showing 0 movies, tv shows, etc in the database. I’m confused. Last time I tried with Kodi on my Yatse trial everything works flawlessly. Is Plex support still in development?
Added: Create combined custom commands that can execute other custom commands in order with optional delays.
Added: Allow hiding custom commands from the list to declutter it while still allowing their use when assigned or used from API/Tasker.
Added: Smart sync support for playlists.
Changed: Custom commands without an icon will now display the first letter of their name when assigned.
Fixed: ANR when long pressing for sync in left menu. (You should always prefer swipe down in category for sync, the long press version prevents differential syncs)
Fixed: Wrong host update when using shared database option.
Fixed: Better workaround to Android Auto issues.
Thanks for your hard work! I’m giving it a try and I think it’ll work nicely when I need my media on my phone but don’t want to use the native Plex app as it ALWAYS finds something it needs to transcode…
I have noticed that it doesn’t quite display sets correctly, though. Some have all of the movies in them and some don’t. Also, is there a way to sort based on custom sort names?
Note: Android 12 have high chances to break Yatse public API. Please join Yatse community (Forum) to discuss about your usage of it to try to build an alternative API.
Added: Support for more mp4/mp4a audio files on local media player.
Added: Active filters are now shown when media lists are empty to easily remove them.
Changed: Allow browsing Book media type for Jellyfin file mode. (You still need to use Music library type for proper audio book integration).
Changed: Yatse wizard now show more technical errors for easier support about Kodi/Network issues.
Changed: Try again to update some Google libraries, if you have issues with action bar positioning please contact support with logs and screenshots/device details.
Changed: Rewrite widget internals to prepare for Android 12. (As always, if you have issues with widgets please contact support).
Fixed: IMDb app no longer starting when clicking IMDB button in cast details.
Fixed: Updated many external libraries, as usual report issues to support.
Fixed: Fix some edges case when streaming from Yatse over VPN.
Fixed: Improve playlists smart sync performance.
Fixed: Personnal mixes now respect offline only setting when casting or playing locally.
Fixed: Remove RTL hack for Kodi 19 as it seems it’s finally fixed on Kodi side.
Fixed: Fix long pressing now playing seekbar for precise seek sometimes leaving the time popup visible.
Just pushed a new beta so will takes some time for Google to accept it (10.8.0B1)
This beta add support for Plex file mode browsing and start implementation of Plex PVR support (EPG / play channels).
If you do want those features please register for beta on Play Store and report back with logs on any issues, as the plex API is complex for that part and I have limited setup to test all the possible cases.
