I’m having an issue with the Plex Web App whereby the Years column is not consistently populating for all tracks (probably 30-40% of tracks are missing data in this field). The Album view however does populate correctly based on year, and the year is visible on the Album home page, so I believe this may be a defect. I have attached two screenshots for reference. I’ve tried re-tagging, refreshing metadata and various other things, with no luck. The fact that so many records are affected makes it hard to troubleshoot, so I’m hoping that there is a known solution for this.
This is a Premium Music library and the Use Embedded Tags flag is checked. The ID3 tag has the Year, however it looks like Plex doesn’t use this on a track level anyway. The Album has been matched correctly in Plex.
Many thanks,
Ed
