Zip Code NOT WORKING HDHomeRun
Server Version#: 1.19.5.3112
Tuner Make/Model: HDHR4-2US
Guide/Lineup name:
Using XMLTV?:
Channel number/Name:
Zip Code search not working, I have also tried installed version 1.20…using ClearOS Linux server.
I have tried everything from every topic I could find, still not working. It was working until I decided to create another ClearOS install just for PlexServer…I already removed Plex off the old server I did not expect to run into any issues with a fresh install. I have tried to get Live TV/DVR going again on both servers no go, the Zip Code search will not work.
Same as OP. Tried everything I know how (different Distros/versions of distros, etc). When I go to setup live tv the “Continue” button just stays faded out after entering zip code. Nothing. Just signed up for lifetime pass. Hoping I can get a refund if I have to go to Fire Recast or some other alternative. Would really like to give Plex a shot but so far not good.
Same here with a fresh install on Windows 10. Only difference here is it appears to (very quickly) start downloading data. Just that there never is any. HDHomerun Quattro tuner here. All appears to be recognized and setup without issue on initial configuration. No idea if the tuners themselves are installed and working as I cannot specify a tuner for livetv, as there is no guide…
