Zoom in on timeline with long press?
On my iPod I have a lot of old time radio shows and some prog rock songs that last between 30-60 minutes. Using Plexamp on these smaller devices it’s very difficult to reverse or fast forward with any accuracy using my big finger on the timeline. I was wondering if there is a way you could add a feature where a long press on the timeline would temporarily zoom in and while still pressing scroll left or right with more accuracy?
Thoughts?
just wanted to let you know that you can enable Music Quick Skip as well if that’s helpful for more surgical skipping around.
Found it! It wasn’t enabled. That should work fine. Since I’m new to this app is there a pdf manual or forum sticky that has all the info in one place? Thanks for your help :slightly_smiling_face:
i recommend the wonderful HOW TO here ~ [How To] Plexamp 3.0 - #135 by Taco many thanks to @sekthree for maintaining it!
