1.16.1 DVR - DVR installation won't accept postcode in Ireland
Server Version 1.16.1.1210
(Ignore the channels, I’m testing this in Australia before advising a friend in Ireland)
Whatever I put in the postcode box (Including the suggested “D01”, I am unable to proceed beyond this point. The “Continue” button remains disabled.
Please advise what Plex is expecting for a postcode for TV services in Ireland?
Thank you for reporting this. I have replicated the problem and referring it to the development team
Problem found. Expect fix to go into the next beta release (hotfix release)
thanks @sa2000. Is there anything I can do to workaround in the meanwhile?
backout to public release and wait for next beta
But be careful, users are now having issues with Gracenote even working as the EPG provider! I await the hotfix/glue fix for Plex to…
Dave
Which issues ?
New beta out
Release Notice for 1.16.1.1273 i has now been added - see Plex Media Server
  • (DVR) Don’t default to Episode 1. (#10207)
  • (DVR) Users in Canada can now set up a new DVR, using a space in the postal code. (#10204)
  • (DVR) Users in Ireland can now set up a new DVR.
  • (DVR) Additionally show channel title in DVR setup where only an internal channel identifier is present.
You do need a full guide refresh to correct the errors for E1
Thank you @sa2000, I can confirm that this has resolved the issue setting up a new DVR for D15.
Further, I can advise that the channels for Saorview Ireland OTA Broadcast match what is being broadcast. The long name in brackets is helpful as the names of the stations changed a little while ago when TV3 was rebranded Virgin Media One and VMs Two and Three appeared.
Good work! :slight_smile:
I’m going to spend a little time comparing guide info from Gracenote to the new, and will open new threads if I find issues worth reporting.
Thanks,
Rob
Thank you for the feedback
@sa2000 quick update the hotfix failed to address the renaming of sporting events. All episodes of MLB, Formula 1, etc still default to Episode 1.
I think we have a full regression of this bug again on Plex Server 1.16.6.1559-a71394a45
I am getting the exact same flow as in the first post, and also in Ireland with a HD Homerun running its latest firmware
I tried the D15 code - that has worked; I am in the west so the codes are different; but its the same channels over ireland so this works fine
I dont know what has changed, but this has been rock solid all night. i cant remember Plex and Live TV working so well. Im tempted to see if DVB-S2 has been looked into more?
Please let me know what Ireland post code does not work and is a regression. You can send me by PM
