If you have the card in Container Station mode, there is no reason this should be detected – but it is being detected.
Now I’m understanding the fault.
- PMS sees the card (this is the problem)
- It starts loading drivers in preparation for communicating
- Communication with the card faults (permission/access)
Which version of QTS and NVIDIA_GPU_DRIVERS do you have installed ?
Apr 27, 2021 17:47:05.777 [0x7fcbf96dab38] DEBUG - [Transcode] Codecs: testing h264_nvenc (encoder)
Apr 27, 2021 17:47:05.777 [0x7fcbf96dab38] DEBUG - [Transcode] Codecs: hardware transcoding: testing API nvenc
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded lib: libcuda.so.1
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuInit
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetCount
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetAttribute
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetName
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceComputeCapability
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxCreate_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxSetLimit
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxPushCurrent_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxPopCurrent_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxDestroy_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemAlloc_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemAllocPitch_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemsetD8Async
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemFree_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemcpy2D_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMemcpy2DAsync_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGetErrorName
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGetErrorString
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuCtxGetDevice
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamCreate
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamQuery
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamSynchronize
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamDestroy_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuStreamAddCallback
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventCreate
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventDestroy_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventSynchronize
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventQuery
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuEventRecord
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLaunchKernel
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkCreate
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkAddData
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkComplete
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuLinkDestroy
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuModuleLoadData
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuModuleUnload
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuModuleGetFunction
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuTexObjectCreate
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuTexObjectDestroy
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGLGetDevices_v2
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsGLRegisterImage
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnregisterResource
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsMapResources
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsUnmapResources
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuGraphicsSubResourceGetMappedArray
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDeviceGetUuid
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuImportExternalMemory
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalMemory
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedBuffer
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuExternalMemoryGetMappedMipmappedArray
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayGetLevel
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuMipmappedArrayDestroy
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuImportExternalSemaphore
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuDestroyExternalSemaphore
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuSignalExternalSemaphoresAsync
Apr 27, 2021 17:47:05.778 [0x7fcbf96dab38] DEBUG - [Transcode] [FFMPEG] - Loaded sym: cuWaitExternalSemaphoresAsync
Apr 27, 2021 17:47:05.844 [0x7fcbf96dab38] DEBUG - [Transcode/JobRunner] Job running: '/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/CrashUploader' '--directory=/share/CACHEDEV1_DATA/.qpkg/PlexMediaServer/Library/Plex Media Server/Crash Reports/1.23.0.4438-5eef0fd80' '--version=1.23.0.4438-5eef0fd80' '--platform=Linux' '--platformVersion=QTS 4.5.2.1630' '--serverUuid=d3b77deba96079eabb18c89a88bbd7422441d420' '--userId=adam@walderston.com' '--sentryUrl=https://sentry.io/api/1233455/minidump' '--sentryKey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx' '--vendor=QNAP' '--model=x86_64' '--device=TS-1277' '--allowRetries=0'
Apr 27, 2021 17:47:05.846 [0x7fcbf96dab38] DEBUG - [Transcode/JobRunner] Jobs: Starting child process with pid 22259
