QuTS / QTS - 4.5.2 / 4.5.3 - Nvidia GPU failures
I am asking, on behalf of all interested parties, for everyone’s assistance.
If you:
  1. Have a QNAP NAS
  2. Are using QTS or QuTS Hero
  3. Have an Nvidia card installed
  4. Using PMS 1.23.0.4482 (which contains QuTS package additions)
AND
  1. The card does not transcode.
Please provide the following information so it may be forwarded to QNAP.
  1. NAS Model
  2. Nvidia Card model
  3. QuTS / QTS version (specify whether QuTS or QTS)
  4. Version of NVIDIA_GPU_DRV
  5. What you see in the Control Panel.
  6. QNAP Support ticket number(s) (this provides more details for QNAP)
I will collect this up and forward today so please be prompt.
1 - TS-473
2 - Quadro P400
3 - QTS 4.5.3
4 - NvKernalDriver 4.5.3.1652 & NVIDIA GPU Driver 5.0.2
5 - Q-202105-20668
1 - TS-873
2 - Quadro P2200
3 - QTS 4.5.3
4 - NvKernalDriver 4.5.3.1652 e driver GPU NVIDIA 5.0.2
5 - Q-202104-18536
I forgot to request:
Screenshot of what QTS shows you.
Should look like:
Thank you!
Forwarding these now.
1 - TS-873
2 - Quadro P2000
3 - QTS 4.5.3.1652
4 - NvKernalDriver 4.5.3.1652 and driver GPU NVIDIA 5.0.2
5 - Haven’t opened any thicket with qnap
May I add I was loosing my mind around this issue. I hope it will be fixed soon :slight_smile:
I did get a follow up response off QNAP saying that they knew the issue and will be resolved in the next QTs patch.
So fingers crossed
Any ETA on the patch ?
well,
they liquidated me saying that the pictures are not compatible …
qnap losers!
But from the answer they gave you I am slightly more hopeful.
@ilboss
Elaborate please ?
“Picture not compatible” ? WTH does that mean ?
Dunno, this is all I got, but it sounds like they’re doing something for it:
Thanks. I can do that in the meantime.
I assume a fix will be forthcoming in the future?
All the best
Mike
QNAP Technical Support has updated the support ticket Q-202105-20668. To check this ticket, go to QNAP Customer Portal . A preview of the updated ticket is shown below:@@@
Hi Michael,
Yes please check the notes for the next incremental update of 4.5.3
So I’m taking that as a ChuckPA effort and enough of us mentioning it to them has prompted them to at least look into it
  1. TVS-673e
  2. GTX1050Ti LP
  3. QTS 4.5.3.1652
  4. NvKD 4.5.3.1652 i NvD 5.0.2 na wersji 4.0.2 wszystko działało poprawnie (po aktualizacji do 5.0.2 pojawiły się problemy)
  5. Q-202104-18335
I’m sorry folks,
I will not let this thread go off topic. I have removed the off-topic posts.
Please stay on QNAP topic.
@ppecet
Thank you for reporting.
QNAP is aware of the reporting problem.
I have confirmed the GT 1050 works.
If your GT 1050Ti does not, I will need the DEBUG log files which capture the failure.
I suspect it’s another QNAP - Driver bug
@ChuckPa
DEBUG log files was send to Qnap support.
This’s 100% of nvdrivers 5.0.2 bug…
Thx for reply
@ppecet
QNAP Support has confirmed this with you?
Is it the device driver or the kernel driver module ?
@ChuckPa
No. Just before upgrading nvdrivers to 5.0.2 (ie on nvdrivers 4.0.2) on the new nvkernel 4.5.3.1652 and system version 4.5.3.1652 everything worked. It is a pity that I did not download the previous version of nvdrivers (4.0.2) because they are now unavailable for download.
I have good news for you then. I searched a little bit and was able to find the 4.0.2 driver on qnap servers here is the link: https://download.qnap.com/QPKG/driver/NVIDIA_GPU_DRV_4.0.2_x86_64.zip
I can confirm that by installing this driver I was able to use hardware transcoding :smiley:
Thanks a lot I can now play with my plex once again :smiley:
Edit: link
@guidePantin
:kissing_heart:
Thank you for Link. However, I am unable to install (via update) this version on my Qnap. I will still try to uninstall and install these drivers.
OK…
I download and I will test!!! :slight_smile:
@ppecet I uninstalled previous drivers first, manually installed (though app center) new one. Reboot nas and it worked :slight_smile:
@broncogr thanks, I edited my post :slight_smile:
