1.24.5.5160 audio codecs failure errors on nVidia Shield
Server Version#: 1.24.5.5160Plex Media Server Logs_2021-10-19_22-08-37.zip (4.3 MB)
Get a error on screen when attempting to play video stream to please check connection and try again later. I see in the console logs there are errors with downloading codecs. The PMS version was updated today to the version specified.
We have temporarily paused this beta version due to this issue. Revert to the previous stable version until the issue has been resolved.
Sorry about this, will try to update you on progress for this.
Is there a way to revert to a older version on nVidia Shield??
There was a new build just pushed to the beta channel which should resolve the issue.
Thank you! I can confirm it has resolved the issue for me.
I’m not seeing the new build, is there something I’m missing? I have a Plex Pass and am on the beta channel.
@drzoidberg33 I do see the issue pop up when doing the following:
  • When autoplay is on for series, and one episode ends and it attempts to play the next episode.
If I back out of the screen, and manually select the episode, it plays fine.
Most likely unrelated to the server, that sounds like a different client-side issue.
