I meant to put this in the General Discussion Category because it seems there are many problems with the latest update, but it got sent to Linux (probably my fault since I don’t post often.) Since upgrading to PMS 1.5.3.3580-4b377d2954 (64 bit Ubuntu 16.10) on Thursday, playing any file with 5.1 dts gets this error: “Conversion Failed. A required codec could not be found or failed to install.” Optimizing the file to a stereo version allows playback. This occurs on both my ROKU TV and my ROKU 2. IT seems the update broke something in PMS’ ability to transcode audio files. Is anyone else having this issue? Is there a fix or workaround coming?
Error “Conversion Failed. A required codec could not be found or failed to install” since 1.5.3 update
