Plex Media Server version 1.9.1.4272 schedules recordings then does not record them. And to explain more…recordings will be working fine and then all the sudden all scheduled recordings do not record…seems like a domino effect…1 fails and all after fail.
Logs are attached. I can attached a picture if necessary of how it looks from the recording schedule tab.
This is being run from a Synology DS1815+ with up to date DSM. Going to revert to 1.7.5 as that seemed stable.
thanks
hmm. Still having the issue with 1.9.1.4272
thanks
I am using PlexMediaServer-1.8.4.4249-3497d6779-x86.spk and seems fine. I record a lot. i tried 1.9 and it blew up again.
Do they not record, record and then get deleted, or do they get stuck at 100% after recording?
Just don’t record at all. The release before 1.9.1 I used get the 100% hangup though.
I’ve rolled back 1.7.5 that is stable for synology.
