2 Movie folders, double poster shows
Apologies if this has been asked before, but don’t see topic.
So, in my library I have a Movies folder, and a 4k Movies folder set as 2 libraries. I also have some movies where I have a 1080p version and a 4k version. On the home screen the same poster shows and the same progression shows.
How does everyone else manage these, or do they have the same issue
Hi there and thanks for the detailed reply. I have changed, for the 4k library, the metadata agent to TheMovieDatabase and forced a metadata rescan.
I also marked the movie as unwatched. Then watched the 4k version enough to have mark as played.
Same issue, shows in the home screen twice. Is there something else I’ve missed?
I also tried labelling the 4k version as ‘The Incredible Hulk (4k)’
many thanks
The agent settings in the library only apply to new additions to that library.
If you want existing movies to be matched using the new agent, you’ll have to either re-match or re-add them all.
Thank you. Now works the way I prefer. Cheers.
