Hello all,
I have 2 problems I’m trying desperately to get figured out…
Problem 1:
I live in KC and my local Fox channel will not tune. It usually states the connection to the Plex Media Server has been lost. Other channels seem to work fine. If I hit retry several times, sometimes it will come in for a bit… like 10-20 seconds and then quits again.
Someone else posted the same problem and they live in Arizona… https://forums.geforce.com/default/topic/1025591/live-tv-via-plex-fox-won-t-tune/
Tried changing several settings both on the Nvidia Shield and Plex. I’m thinking it is problem with the Nvidia Shield because the Google Live Channels app has a problem getting Fox too.
Problem 2:
The channel scan is skipping over my ABC station 9.1. I know it is NOT because I’m out of range. I fired up Google’s “Live Channels” app and did a scan and it finds it fine and tunes into it fine.
I’ve re-run the channel scan about 3 times and it never finds that channel.
According to my tvfool.com report, I’m well within the range with my Mohu Leaf 30 and the CW channel which is the same distance is found just fine.
Nvidia Shield 16gb - All latest updates… just purchased a week ago
Hauppauge WinTV-DualHD TV Tuner
Mohu Leaf 30 Antenna
Latest Plex updates as of 11/26/17
Any help with these issues would be greatly appreciated.
Thanks,
Doug
