When play film from local machine throw app max video quality is 1Mbps. In setting quality for video set as “Original”.
I’m having similar trouble. I can only go up to 720p 2mbps quality, even though the file is on the same computer as the program. When I go into settings, I appears to have direct play set to on, so I’m not sure what the trouble is.
Have you upgraded to the latest beta build?
3.0.17 the problem is still actual.
