@OttoKerner
Apr 12, 2017 14:17:00.816 [4568] DEBUG - Scaled up video bitrate to 48448Kbps based on 1.500000x fudge factor.
Apr 12, 2017 14:17:00.816 [4568] DEBUG - Scaled maximum bitrate for resolution reduction to 21532Kbps.
Apr 12, 2017 14:17:00.816 [4568] DEBUG - Codecs: testing mp3_mf (encoder)
Apr 12, 2017 14:17:00.816 [4568] DEBUG - Codecs: testing aac_mf (encoder)
Apr 12, 2017 14:17:00.816 [4568] DEBUG - Codecs: testing ac3_mf (decoder)
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: received PLEX_PROTOCOL_ANY from client, selected protocol hls
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: analyzing media item 53951
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): Direct Play is disabled
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): media must be transcoded in order to use the hls protocol
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): selected subtitle cannot be converted to a compatible format, burning into video stream
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): avoiding video remux due to burned subtitle stream
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): no remuxable profile found, so video stream will be transcoded
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: computed resolution bounding box of 1280x720.
Apr 12, 2017 14:17:00.816 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): selected media 0 / 53951
Apr 12, 2017 14:17:00.816 [4568] DEBUG - Streaming Resource: Changing decision parameters to fit bandwidth limit of 3000kbps
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): Direct Play is disabled
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): media must be transcoded in order to use the hls protocol
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): selected subtitle cannot be converted to a compatible format, burning into video stream
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): Direct Streaming is disabled, so video stream will be transcoded
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): no remuxable profile found, so video stream will be transcoded
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: computed resolution bounding box of 1280x720.
Apr 12, 2017 14:17:00.832 [4568] DEBUG - Scaled up video bitrate to 48448Kbps based on 1.500000x fudge factor.
Apr 12, 2017 14:17:00.832 [4568] DEBUG - Scaled maximum bitrate for resolution reduction to 21532Kbps.
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): Audio Direct Streaming is disabled, so video’s audio stream will be transcoded
Apr 12, 2017 14:17:00.832 [4568] DEBUG - Codecs: testing mp3_mf (encoder)
Apr 12, 2017 14:17:00.832 [4568] DEBUG - Codecs: testing aac_mf (encoder)
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: Der Pate - Teil 3 (1990): selected media 0 / 53951
Apr 12, 2017 14:17:00.832 [4568] DEBUG - Streaming Resource: Reducing playback quality for 2857kbps stream bitrate: video resolution to 720x406, audio channels to 2
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: computed resolution bounding box of 720x406.
Apr 12, 2017 14:17:00.832 [4568] DEBUG - Scaled maximum bitrate for resolution reduction to 6829Kbps.
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: received PLEX_PROTOCOL_ANY from client, selected protocol hls
Apr 12, 2017 14:17:00.832 [4568] DEBUG - MDE: analyzing media item 53951
