Plexamp can working on WiFi,but not 5G
Server Version#: 1.30.2.6563
Player Version#:4.6.1
Hi,I’m new here.
I have a issue as https://forums.plex.tv/t/plexamp-ios-not-working-properly-on-4g/700011,and I am make sure the server is signed in and remote access is enabled.
At the same time,the Plex movie App is working good on 5G or WiFi.
I provide plexamp logs,Looking forward to your reply.
87138468439827.zip (43.5 KB)
Some sort of issue connecting to your server:
Feb 04, 2023 10:14:17.981 [Javascript] WARNING - DEVICE: Server connection https://123-154-153-66.80f704b6fd074385873fb603a477de4b.plex.direct:32400 didn't work for TiFang-DSM: HTTP status -35
This is the error:
CURLE_SSL_CONNECT_ERROR (35)
A problem occurred somewhere in the SSL/TLS handshake. You really want the error buffer and read the message there as it pinpoints the problem slightly more. Could be certificates (file formats, paths, permissions), passwords, and others.
My guess is that your cellular provider is trying to proxy/block. Try exposing your server on port 443 or 8443 and see if it makes a difference.
