Server Version#:1.42.2.10156
Player Version#:5.93.2 Plex for LG
Server OS: Windows 11 24H2
Media Quality: 15 Mbps average, direct play 4K content
Network Information and topology: 1Gbps wired local network direct to router (100 Mbps measured wired, 600 Mbps wireless)
When playing 4K HDR content via the Plex app on an LG C4, playback pauses/buffers every few minutes. The same media streams flawlessly on other clients (e.g., Plex Web on laptop) from the same server. The issue occurs on both Wi-Fi (600 Mbps) and wired Ethernet (100 Mbps) connections. Network throughput and server performance (HDD speed) are not the bottleneck, which were tested via Wireshark recordings of buffering events and stress tests of the HDD which was consistent.
This seems to be a clear issue within the WebOS Plex app itself. I am able to stream other 4K content from other sources (AppleTV, Amazon, Netflix) without incident, but Plex specifically is unable. The same content is stable on all other platforms within the same room via wifi and other wired sources.
Logs are uploaded. I can provide Wireshark (filtered to relevant event) supporting that network connection quality and speed are NOT the issue if needed.
In the log, buffering events are at 13:37:43, 13:41:02, 13:45:41, and 13:46:12
Steps to Reproduce
Play any 4K HDR (10â20 Mbps) file via the Plex app on the LG C4.
Playback proceeds normally for several minutes, typically 10-20, sometimes less.
The stream pauses or buffers for 3â15 seconds, then resumes. Occasionally the app will freeze, resume, and audio/video will be desynchronized and require an app restart
Plex Media Server.log (2.5 MB)
log is for wired connection
