Server Version#: 1.32.3.7162
Player Version#: 9.23.0.1746 (80d0211) - on My TV
Plex Server: AMD Ryzen 7 (8c/16t) / Windows 10 / 16GB RAM / 2.5Gb/s NIC
Plex Storage: Synology NAS DS920+ / 4 HDD’s in SHR2 “raid” (WD Red WD102KFBX)
My TV: Sony Bravia X75K [VU3] (Android 11) - Using WiFi
Friends TV: Sony Bravia [VH1] (Android 10) - Using WiFi
I’ve been using Plex for 7+ years with no issues until I recently decided to get a 4K TV and started putting 4K movies on my Plex.
Whenever I try to watch a 4K movie on my Sony TV while on my local network it gets transcoded down to 1080p HDR. When I got into the “Playback Info” screen while it’s playing, the “Transcode reason” is “Resolution or bitrate exceeds maximum allowed”.
My friend who access to my Plex library is able to play this exact same move from my Plex server and it shows as 4K HDR.
For testing, I gave him the same file to put on his Plex server that I have on mine. When I stream this same file from him on my TV it shows as 4K HDR. He’s running his Plex server directly on his own Synology NAS.
I’ve tried plugging a network cable into my Sony TV to see if that fixes anything and nothing.
I’m at a total loss for what the problem could be.
Edit: I forgot to mention that I’m only having this issue when I stream to my TV locally. If I stream this same movie from my Plex server to my Gaming PC, it shows as a 4K stream no problems.
Edit 2: Forgot to mention that I have a Plex Pass account.
One the Plex server, check that the network interface is a private, not public, network.
Settings → Network & Internet. Properties to change.
Play something from your server on your Sony.
Monitor playback via Plex Dashboard → Now Playing + Expanded View.
Does the connection show as local, remote, or indirect?
Windows see’s my Network Adapter as “Private” versus
While playing a movie on my Sony TV, I can see that “Remote” bandwidth was 0 and “Local” bandwidth jumped up to ~40Mbps.
Edit: To clarify your point about the “expanded” view.
Plex server shows that it’s sending this movie to my “Plex for Android(TV) - BRAVIA VU3”
Video 4K (HEVC Main 10)
→ 1080P (H264) - Transcode
Audio: English (DTS HD MA 5.1)
→ OPUS - Transcode
Edit 2: same info for home PC
Plex server shows that it’s sending this movie to my “Plex for Windows - PC-Hostanme”
→ Direct Play
Server logs were always enabled, but i enabled verbose logging, then waited about a minute, ran a 30 second test, waited a minute, and then downloaded the logs.
I’m very happy on command line : ) also, you mis-spelled deeply : ) Thanks for the suggestion.
While in the main directory, I ran the following command: “Plex Media Scanner.exe” --list
Which returned the below:
1: Music
2: Photos
6: ZZ-Long Form Content
4: ZZ-Movies
7: ZZ-Movies-4K
5: ZZ-Music-Videos
3: ZZ-TV-Shows
Then I ran: “Plex Media Scanner.exe” --list --section 7
I wont’ post all of the output, but it returned the following:
30217: Alita: Battle Angel
29211: Avatar
29212: The Way of Water
I then ran your command: “Plex Media Scanner.exe” --analyze-deeplu --item 29212
Not sure if something is supposed to display on cmd line or not. But I tried streaming it again on my Sony TV and it’s still being transcoded down to 1080p.
I was curious how this could be the problem but only for me streaming the movie from inside my own network. But thanks again for the suggestion.
I think your friend has turned off tone mapping on his server, which allows the video to direct play. You have it enabled on your server, so that is triggering the transcode. If you turn it off, it should direct play.
If you want tone mapping, then check in the Plex for Roku app settings under 'Video" → "Maximum H264 level. Looks like you have it set to 4.2. When tone mapping, PMS will transcode to H264. Level 4.2 does not allow 4K. Raise that to 5.1 or higher and see if that helps.
Also, your logs still have verbose info. You have to restart PMS when you turn off a logging level, for it to take effect.
Can you post the xml info for the movie? I’m seeing this in the log.
Streaming Resource: Reducing playback quality for 190476kbps
That’s a really high bitrate. Looks like your app has the local quality set to 20 Mbps. Since that video is so high, going from 190Mbps to 20 Mbps, there isn’t enough data to produce a 4K video.
I made sure that my TV is on the 5Gh’z Wi-Fi connection, and as mentioned in my original post I’ve also tried a physical ethernet connection with no luck.
