7.1 Audio Issue on Samsung 55KU6270
I’m not sure if this was recent, but 5/6 minutes into playing, my media files with a 7.1 (AAC) track loses audio. It plays fine in the beginning for a few minutes, no lag or stutter, but 5-6 minutes, gone, and doesn’t come back. If I exit and replay the movie from the same time code, audio stays and then goes after a similar time.
I have turned off DTS from audio options in my TV. And tried different variations of Direct Play and Stream (on/off, off/off, on/on) - direct play on, stream off with DTS off can play the audio for slightly longer but then it goes out again.
No problem for media files with other type of tracks (tried AC3, AAC 5.1)
Any idea? Running plex off my local network - PC and TV both wired to a router.
P.S :On a different topic, can you stream videos in your TV via the plex app if your TV is connected to the TV via HDMI?
You might want to organize your report and have it include more details as described in
