[AAC 2.0 / x264 mp4] Video is sluttering / not playing
Hi, I’ve difficulties playing a 720p video AAC VBR/x264 on rasplex. The video is sluttering like hell.
Looking at the server, the video is direct played. I’ve set up rasplex to passthrough the audio to my AV receiver.
The videos plays like a charm on plex web (wifi), Plex app on iPad.
I can play fullbitrate x264 1080p video on my raspberry pi 2 but this one for an unknown reason is not working properly (see video details below)…
Any idea where it could come ? Any known issue regarding specific audio format like AAC VBR ?
Thanks for your help!
My configuration:
NAS SYNO DS215J running latest version of PMS — Gigabit switch — Raspberry pi 2 (Rasplex 1.0.3) — HDMI — AC receiver — HDMI-Samsung TV
Media details:
Média
Video Resolution 720p
Durée 47:09
Bitrate 3157 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Container MP4
Video Frame Rate PAL
Web Optimized Oui
Audio Profile lc
Has 64bit Offsets 0
Video Profile constrained baseline
Partie
Durée 47:09
Size 1.04 GB
Audio Profile lc
Container MP4
Has 64bit Offsets 0
Web Optimized Oui
Codec H264
Bitrate 3026 kbps
Bit Depth 8
CABAC 0
Chroma Subsampling 4:2:0
Durée 47:09
Frame Rate 25.000 fps
Frame Rate Mode cfr
Has Scaling Matrix 0
Height 720
Level 3.1
Pixel Format yuv420p
Ref Frames 1
Scan Type progressive
Stream Identifier 1
Width 1280
Codec AAC
Chaînes Stéréo
Bitrate 128 kbps
Audio Channel Layout stereo
Bitrate Mode VBR
Durée 47:09
Profile lc
Sampling Rate 44100 Hz
Stream Identifier 2
Codec SRT
Langue English
Format SRT
Codec SRT
Langue Français
Format SRT
Codec SRT
Langue English
This is the second time I’m seeing issues with a 3.x level H.264 video, not sure if it is coincidence or not but does it do this with any 4.1 level H.264 videos?
I don’t suspect the AAC is the problem since even the RPi1 shouldn’t have issues playing it.
Any special sync settings?
You could try running through the PMS optimiser https://support.plex.tv/hc/en-us/articles/214079318-Media-Optimizer-Overview
Regards
It’s the first time I see this on any of my x264 videos… I’ve no special sync settings.
The media is being transcoded right now, I’ll let you know but it will be probably work. There something in this video encoding Rasplex doesn’t like…
