Ability to sort has disappeared on nvidia shield?
I now have found success also. I went into my plex library (pms) on the pc.
sorted each folder from within pms that I have shared on my network, how I prefer.
went back to each nvidia shield and now the sort by feature has reappeared.
allowing me to view in the order that works for best for me. or the ability to change the sort on the fly, if needed.
@FordGuy61
FYI - since the Plex Player client on Android automatically updates to latest version, and I don’t see a way to disable that ā€œfeatureā€, I bit the bullet and upgraded PMS to 1.19.3.2852. I had to install a fresh PMS due to jails EOL on FreeNAS. My prior mount points were less than elegant so I scrapped trying to copy metadata from the old PMS. Good news is the the poster updates were relatively quick for the libraries.
I’m still trying to figure out how to remove all references to the old PMS.
But, sorting the Library is back and working as intended on Nvidia Shield. And - the TV Guide also works in this PMS version.
Thanks again for the assistance @FordGuy61 and @BigWheel.
Ouch! Didn’t know you would have to jump through so many hoops to update PMS.
Regarding clients, you can disable auto-update in the Google Play App Store on AndroidTV and mobile devices. It is a global setting for all apps. I don’t know a way to do that on an app by app basis. You can also disable auto-update for FireTV devices. It is somewhere in the FireTV settings. I haven’t used a FireTV in quite some time, so can’t tell you exactly where it is located (probably under Settings → Apps LOL).
Screenshot from Google Play store settings on my Android phone. Very similar on Android TV.
