Sorting options removed from library view
I currently use an Android TV to run my Plex streaming and as of 2 days ago the UI has seemed to have changed and now the libaries cannot be sorted. This has made the app significantly harder to use and I cannot understand why a useful UI element would just be removed and not given a replacement.
Was this done in error? Has the sorting been hidden under some mysterious hotkey?
I am having the same issue, though specifically on the Shield Plex App. The option for Library is there, but when selecting it, there is no longer any filters for “sort by” etc, so the only way to navigate the library is manually from top to bottom.
I reverted the app back to default on the Shield and the options came back. I then updated the app again to latest and they are gone again, so I assume this is a change on a recent update as it only occurred in the last week.
