Absolute Order Problem for "One Piece"
Server Version#: 1.23.1.4571
I recently started changing my animes to absolute order. I don’t know why, but somehow PleX doesn’t manage to match the episode names right for the series “One Piece”. I tried some things out. Before, some episode names were assigned, but there were huge gaps over wide numbers of episodes with the only pattern that there were many episodes in a row unassigned. At least the specials were assigned correctly. Now, not even one episode or special is assigned a name anymore, although the series is matched correctly.
How are my settings?
  • Specials are saved for example “…\TV Shows\One Piece\Specials\One Piece - S00E04 - Abenteuer auf der Spiralinsel.mkv”
  • Episodes are saved for example “…\TV Shows\One Piece\One Piece - E01 - Hier kommt Ruffy, der künftige König der Piraten.mkv” (I applied the same structure for InuYasha, where everything works without a problem; This is what FileBot Renamer suggested using {plex})
  • In the settings for One Piece: Order Episodes (don’t know if that is the original setting name, I use PleX in German language) “TheTVDB (Absolute)”.
  • In my library settings: Scanner “Plex TV Series”, Agent “Plex TV Series”
Do you have any idea on how to solve this?
Try S01E01 instead of E01.
Plex documentation: Naming & Organizing Your TV Shows
Standard, Season-Based Shows
Most television shows have episodes organized into seasons. To name season-based shows create files with the season and episode notation sXXeXX :
  • /TV Shows/ShowName/Season 02/ShowName – s02e17 – Optional_Info.ext
This is only an example. The important bit in the file name is the appropriate season and episode number notation s02e17 which in this example means Season 2 Episode 17 It does not matter if you use dashes, dots or just spaces.
There are no Specials listed for the Absolute order of the show at TheTVDB.com. ワンピース - TheTVDB.com
I’m not sure exactly how Plex will handle files in a Specials / Season 00 folder. It will probably list them as episode 1, episode 2, etc, but without metadata, as there is nothing at TheTVDB for it to match against.
Doesn’t change anything. I had that before at some point. If I move everything in a Season 01 folder named that way, I get metadata but only for the “real” first season, not for the rest.
They seem to have it in “Unassigned Episodes”… Strange thing.
Is there any workaround? Else I must switch back to “Aired Date” but this ordering by seasons is a bit useless in this case I think.
Thoughts:
  • Use three digits for all episode numbers.
  • Configure Plex for absolute ordering.
  • You may have to Plex Dance the entire show to pick up the changes. You can always just add in a few shows to make sure things work, then add the rest.
I ran a test on my system:
PMS v1.23.2.4600; Synology DS918+
Naming & organization:
Edit show and configure for Absolute ordering:
Result:
Regarding Specials…
I do not see a workaround when using Absolute ordering.
The files I place in Season 00 show up as Episode 1, Episode 2, etc.
I cannot get Plex to read local metadata from the files, even when using MP4 container and telling Plex to read local metadata.
