@ZeroQI said:
@cbussa Because your smiley is creepy… It looks like the joker trying to really smile with blackface make-up… That’s why people look at you… still…
Thanks for looking at me – even if you **are ** crosseyed.
Plex distributed transcoding backend Hmmm. I’ll have to look into that.
OP1a, ED2b, etc – oops, misspoke there, I meant that they ARE supported, so is all the info iterated on the back end or is there some state stored there? Otherwise how does it know OP2/105 comes after OP1d/104?
“if you just dumped” – Nyaa, I wouldn’t do that. Although occasionally I’ll get lazy and see what decodes correctly and then fix the remainder.
Sure, I’ll attach the logs – I’ll strip out the other MKV files and rescan so it’ll be easy to see.
Oh! The message links earlier were just me referencing previous searches (basically you) I tried to use to solve the problem. I hate people that say “Solve my problem, and BTW I’ve not even opened the box it comes in yet.” Wha…?? if you don’t put at least SOME effort into it, then why on Earth should I – unless it’s literally my job and you’re paying me to do so. [Hi Jerry! You reading this?
I’ve killed the log files before 11PM last night, they shouldn’t be useful. I’ve still got them if you think they are, though.
These are NOT the beta log files! Plex log files, my verbose description file. You want to read the last 40 lines of the latter file, it has the manual details of what the Plex log will show.
Beta branch. Sigh, I tire of updates, of bugs, of fixes; I’ve been seeing them for on 40 years now. I want “known stable works” or “fixes obvious broken”, which will STILL have bugs but maybe less-so. Or maybe “yum/apt update” which are mostly automatic, but NOT like Chrome or Windows which occasionally remakes the GUI and muscle memory workflow. Sigh … if you really want me to, I will. Github Hama Beta, right?
I get a bit verbose now and then, sorry about that. Thanks a bunch for helping out, I know you’re busy! ASS/Hama works great and I’ll rename files or just dump 'em in Extras if I have to.
