Absolute Series Scanner (for anime mainly)
@ZeroQI I changed my directory structure and now everything is scanning in without any issues. Also all the metadata pulled in using your plugin without problems using this directory structure. I cant explain why but here is my new structure for anyone else that runs into something similar.
Media
–Youtube
----(Cocomelon - Nursery Rhymes) - Color Songs [PLT1rvk7Trkw4_iqrdGPt_oan15oA1_3cL]
------Color Songs - S01E1 - Color Songs Collection _ Red, Orange, Yellow, Green, Blue, Purple, Pink - Cocomelon (ABCkidTV) [LWtonKSWzF0]
------Color Songs - S01E2 - Color Song - Red _ Cocomelon (ABCkidTV) Nursery Rhymes & Kids Songs [sP9yiM1htqQ]
----(Cocomelon - Nursery Rhymes) - Finger Family Songs [PLT1rvk7Trkw6dKQ_e0lgcKK93zy8dG3IV]
------Finger Family Songs - S01E01 - Finger Family Vehicles (2D) _ +More Nursery Rhymes & Kids Songs - Cocomelon (ABCkidTV) [-QIAvKjNgDY]
------Finger Family Songs - S01E02 - Finger Family Farm Animals (2D) _ Cocomelon (ABCkidTV) Nursery Rhymes & Kids Songs [MaHWFODvtfU]
----(Tested) - Inside Adam’s Cave [PLJtitKU0CAehsdcybehbPFHObmWsKtQcY]
------Inside Adam’s Cave - S01E01 - Last Call for Adam’s One Day Builds T-Shirt! [GEhBPI2QVBI]
------Inside Adam’s Cave - S01E02 - Adam Savage’s One Day Builds - Kit-Bashing a Robot! [QCBcWm85gWo]
Thanks for that precision, must be a Plex issue caused by path(+filename?) length then…
I wonder what Plex’a recent blog post about shutting down plugins means for this excellent tool. I hope it keeps working.
It means nothing because this is not a plug-in.
-Shark2k
I am trying to get the Absolute Series Scanner working on my Plex install (running on FreeNAS) but it doesn’t seem to work. It shows up as an option as a scanner in the library, however it doesn’t find new entries I add to the library and doesn’t add new episodes to shows.
I currently use MyAnimeListAgent with the default plex scanner but wanted to take advantage of the absolute series scanner for my episode numbering.
I don’t appear to have any logs in /var/db/plexdata/Plex Media Server/Plug-in Support/Data
There isn’t even a com.plexapp.agents.hama directory.
Any advise would be appreciated.
The only log I am finding is the Plex Media Scanner.log. It shows:
Oct 12, 2018 23:19:10.111 [0x809406800] INFO - Plex Media Scanner v1.12.2.4929-29f6d1796 - FreeBSD PC amd64 - build: freebsd-x86_64 - GMT -05:00
Oct 12, 2018 23:19:10.114 [0x809406800] ERROR - Failed to determine system locale: locale::facet::_S_create_c_locale name not valid. Defaulting to en-US.
Oct 12, 2018 23:19:10.114 [0x809406800] INFO - FreeBSD version: 11.0-RELEASE (FreeBSD 11.1-STABLE #0 r321665+9902d126c39(freenas/11.1-stable): Tue Aug 21 12:24:37 EDT 2018 root@nemesis.tn.ixsystems.com:/freenas-11-releng/freenas/_BE/objs/freenas-11-releng/freenas/_BE/os/sys/FreeNAS.amd64), language: en-US
Oct 12, 2018 23:19:10.114 [0x809406800] INFO - Processor Intel® Xeon® CPU E5-2620 v4 @ 2.10GHz
Oct 12, 2018 23:19:10.114 [0x809406800] INFO - /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex Media Scanner --scan --refresh --section 7
Oct 12, 2018 23:19:10.106 [0x809406400] WARN - Default locale is invalid; falling back on classic+UTF-8
Oct 12, 2018 23:19:10.118 [0x809406400] DEBUG - Opening 20 database sessions to library (com.plexapp.plugins.library), SQLite 3.13.0, threadsafe=1
Oct 12, 2018 23:19:10.253 [0x809406400] DEBUG - Scanning Anime Series - New Releases using en(Absolute Series Scanner) with 2308 current media items and 1 section locations in the database…
Oct 12, 2018 23:19:10.253 [0x8110b1c00] DEBUG - HTTP requesting GET http://127.0.0.1:32400/:/metadata/notify/cullTimeline?librarySectionID=7&sinceTime=1539403150
Oct 12, 2018 23:19:10.254 [0x809406400] DEBUG - Performing a scan with ‘Absolute Series Scanner’ (language: en virtual: 0).
Oct 12, 2018 23:19:10.254 [0x809406400] DEBUG - * Scanning /media/Anime New Releases
Oct 12, 2018 23:19:10.258 [0x809406400] ERROR - No module in VideoFiles
Oct 12, 2018 23:19:10.258 [0x809406400] ERROR - Error scanning directory .
Oct 12, 2018 23:19:10.259 [0x809406400] ERROR - No module in Absolute Series Scanner
Oct 12, 2018 23:19:10.259 [0x809406400] ERROR - We got an error scanning in /media/Anime New Releases
Oct 12, 2018 23:19:10.334 [0x809406400] DEBUG - Directory had 43 files, database had 42 files, can’t skip.
Oct 12, 2018 23:19:10.335 [0x809406400] ERROR - No module in Absolute Series Scanner
Oct 12, 2018 23:19:10.335 [0x809406400] ERROR - We got an error scanning in /media/Anime New Releases
This is listed under the “known issues” however it says “You bloody downloaded the web page and not the actual py file” however I double checked the RAW on github and my py file matches.
@sweetaction if you have the same code as the raw, then the code crashed due to an error in the code. i need the file list to reproduce your issue, as latest code doesn’t crash for me
Attached is the complete log from “Plex Media Server/Logs/Plex Media Scanner.log”
Plex Media Scanner.log (472.5 KB)
it crashes definitely but cannot reproduce the issue.
I need your scanner code version and filelist for your library series.
Might be something specific for your os in one code part only, needing an explicit import in the code…
Any hints in the series scanner logs my scanner created in hama agent data folder?
Had to reinstall windows and thus my scanner. Seems a few of my anime aren’t showing now.
Full Metal Panic! Invisible Victory
Full Metal Panic! The Second Raid
Full Metal Panic - Fumoffu
Cowboy Bebop
located on my external drive in the “Anime Series” Directory. Could be missing more just haven’t had time to reconcile.
I attached a few logs.
edit
NVM I fixed it. I just deleted the library and recreated it. For whatever reason that worked.
I’m using the TVDB as my main agent (b/c I like English titles), for whatever reason, the scanner wouldn’t pick up the Full Metal folders unless they were all considered seasons and placed in the same folder. That is how TVDB has it, but I thought the scanner would pick up the folders regardless.
Doesn’t bother me, I just remember having them as separate shows before.
Full Metal Logs.zip (23.1 KB)
ZeroQI I don’t see any other logs created other then what I uploaded. I am running in a FreeNAS jail. Is there anything else I can provide to help figure this out?
@brushrop03 @sweetaction scanner crashes. Please check you use latest version, we jest correcting crash issues. you probably didn’t select ass for scanner for the library and it workes using default scanner.
Use https://github.com/ZeroQI/Absolute-Series-Scanner/wiki/Batch-file-to-create-filelist.txt-and-dummy-library-from-it and attack your scanner file, version of the os and filelist for me to reproduce
Hi ZeroQI,
I have a weird bug. My scanner will not read the local “tvdb4.mapping” file.
It detects the file being in the folder, but it will not read the contents, I verified this by moving the file from the folder.
When the file is present, all episodes will end up in one season, but without the file the data is being pulled from the “tvdb4.mapping.xml” file from github.
found the following error in the logs, looks like it might have something to do with my personal mapping file:
Error opening tvdb4 mapping, Exception: ‘invalid literal for int() with base 10: ‘\xef\xbb\xbf01’’
Any ideas how I can fix this?
EDIT:
I have reacreated my mapping file, and it does seem to work now. I think I could have simply changed the extension of the .xml file, thus keeping some of the .xml’s properties in my mapping file… dumb mistake I overlooked. Added this to my post in case someone else comes across the same problem in the future.
@ZeroQl I have been using your Anime scanner for quite a while and it has been fantastic for managing my library of shows. Thank you very much for all the hard work.
I have recently noticed a problem where folders that I delete from my anime library remain in the list of available shows and I am unable to get rid of them. Scanning the folder and/or emptying trash has no effect. I have updated Plex server, the scanner, and Hama Bundle, also with no effect. If you can help me identify a solution I would greatly appreciate it.
I’m running Plex 1.13.9.5456-ecd600442 on the latest build of Windows 10. My scanner and Hama bundle were updated at the end of October.
https://support.plex.tv/articles/201447966-why-does-content-i-deleted-on-my-drive-still-show-up/
Seem like empty trash failure.
Does the media show up as missing? If so, the scanner did its job.
Hello, I am new to Plex and Absolute Series Scanner / HAMA. I think I set it up correctly according to the documentation, but when trying to add a new library with anime TV series, nothing appears. The scanner appears in the drop-down menu when creating a new TV show library, so I believe it is installed correctly.
Plex Media Scanner.2.zip (1.4 KB)
Basically one error repeating over and over again.
“U:\Serialy” is a mounted network folder.
I am really not sure where the problem is (bug in Python code, something wrong with that Token, my installation).
Plex version 1.13.9.5456
Absolute Series Scanner.py downloaded today
The thumbnails for the shows in question are not marked as missing. It’s not until I navigate to, and click on the individual episodes that there is a message that the media is missing. So it appears that the shows are indeed still in my library. I have a couple of dozen shows that I have erased so it’s becoming a bit of a mess.
@ZooM this character crashes the scanner, is it in the library or path name?
https://www.charbase.com/00e1-unicode-latin-small-letter-a-with-acute
@vulcan300 I am afraid it is Plex behaviour at this point. Check if the scanner is crashing, therefore not removing, i could correct the scanner but if not, it’s Plex that has an issuebut if
@ZeroQI Hello, this character is not in any path, folder name, or file name. However, it is in the name of the anime TV series library in Plex (when you add a Library and define whether it is Movies, TV series, etc. and then write its name).
Is this something you can fix, or is it Plex’s fault? Obviously, I could just rename the Library, but would like to resolve this correctly (if there is any bug involved).
I’m getting this on the latest version of plex pass, but works with no errors on 1.14.1.5488-1-01 any ideas?
Feb 10, 2019 02:36:25.584 [0x14e598e7c740] DEBUG - Directory had 13 files, database had 0 files, can't skip. Feb 10, 2019 02:36:25.597 [0x14e598e7c740] ERROR - No module in Absolute Series Scanner Feb 10, 2019 02:36:25.597 [0x14e598e7c740] ERROR - Error in Python: Looking up module: Traceback (most recent call last): File "/config/Plex Media Server/Scanners/Series/Absolute Series Scanner.py", line 20, in <module> from lxml import etree # fromstring ImportError: libexslt.so.0: cannot open shared object file: No such file or directory
