Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): ATV 3, 6.1.1
The DNS server set on the ATV (found under the ATV settings > general > network > DNS):10.0.1.125
The local IP address of the device that PlexConnect is installed on:10.0.1.125
The device and operating system (including version number) that PlexConnect is installed on:Windows 8.1
The device and operating system (including version number) that the Plex media server (PMS) is installed on:Windows 8.1
The Plex media server (PMS) version number you are running (do not put 'latest'):0.9.9.7
The local IP address of the device that the Plex media server (PMS) is installed on:10.0.1.125
The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any non-standard setup e.g. Plexify or a fork.0.3.1+
The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect]
enable_plexgdm = True
ip_pms = 192.168.178.10
port_pms = 32400
enable_dnsserver = True
port_dnsserver = 53
ip_dnsmaster = 8.8.8.8
prevent_atv_update = True
enable_plexconnect_autodetect = True
ip_plexconnect = 0.0.0.0
hosttointercept = trailers.apple.com
port_webserver = 80
enable_webserver_ssl = True
port_ssl = 443
certfile = C:\PConnect\PlexConnect-master\assets\certificates railers.pem
loglevel = High
logpath = .
Detail on the media file if it is an issue related to playing a media file - I choose Movies or Television, and it goes to the screen to display whatever content I might have in either collection, and "Accessing Trailers" sits there, I've left it at least 10 minutes. I installed the cert using iPhone Configuration Utility.The Plex library, prior to selecting Movies or Television, shows my library scrolling past, so I guess it sees it, but cannot display it for some reason...Log is below. Also, all outgoing & incoming ports are open in the windows firewall, and python is allowed. Any help would be appreciated.
c:\PConnect\PlexConnect-master>PlexConnect.py
16:20:32 PlexConnect: ***
16:20:32 PlexConnect: PlexConnect
16:20:32 PlexConnect: Press CTRL-C to shut down.
16:20:32 PlexConnect: started: 16:20:32
16:20:32 PlexConnect: Version: 0.3.1+
16:20:32 PlexConnect: Python: 2.7.6 (default, Nov 10 2013, 19:24:18) [MSC v.1500
32 bit (Intel)]
16:20:32 PlexConnect: Host OS: win32
16:20:32 PlexConnect: IP_self: 10.0.1.125
16:20:32 DNSServer: started: 16:20:32
16:20:32 DNSServer: ***
16:20:32 DNSServer: DNSServer: Serving DNS on 10.0.1.125 port 53.
16:20:32 DNSServer: intercept: ['trailers.apple.com'] => 10.0.1.125
16:20:32 DNSServer: restrain: ['mesu.apple.com', 'appldnld.apple.com', 'appldnld
.apple.com.edgesuite.net'] => 127.0.0.1
16:20:32 DNSServer: forward other to higher level DNS: 8.8.8.8
16:20:33 WebServer: started: 16:20:33
16:20:33 WebServer: ***
16:20:33 WebServer: WebServer: Serving HTTP on 10.0.1.125 port 80.
16:20:33 WebServer: WebServer: Serving HTTPS on 10.0.1.125 port 443.
16:20:56 DNSServer: DNS request received!
16:20:56 DNSServer: Source: ('10.0.1.116', 58149)
16:20:56 DNSServer: Domain: trailers.apple.com
16:20:56 DNSServer: ***intercept request
16:20:56 DNSServer: -> DNS response: 10.0.1.125
16:20:56 WebServer: serving /js/application.js
16:20:56 WebServer: serving .xml: /
16:20:56 PlexAPI: ***
16:20:56 PlexAPI: looking up Plex Media Server
16:20:57 PlexAPI: GDM: Servers discovered: 1
16:20:57 PlexAPI: Servers (local+MyPlex): 1
16:20:57 WebServer: serving .xml: /PlexConnect.xml
16:20:58 WebServer: serving /js/utils.js
16:20:58 WebServer: serving .xml: /library/sections
16:21:00 WebServer: serving /js/utils.js
16:21:00 WebServer: serving .xml: /library/sections/2/recentlyAdded
16:23:43 DNSServer: DNS request received!
16:23:43 DNSServer: Source: ('10.0.1.116', 64086)
16:23:43 DNSServer: Domain: trailers.apple.com
16:23:43 DNSServer: ***intercept request
16:23:44 DNSServer: -> DNS response: 10.0.1.125
16:23:44 WebServer: serving .xml: /library/sections/2
16:23:48 WebServer: serving /js/utils.js
16:23:48 WebServer: serving /js/updateXML.js
16:23:49 WebServer: serving .xml: /library/sections/2
Set an outbound rule for Python.exe in your firewall.
If you are still having issues set log level in settings.cfg to “High” (note the capital H) and post a new log.
If you are still having issues set log level in settings.cfg to "High" (note the capital H) and post a new log.
Loglevel is set to High already, see config above. Also, python.exe is allowed in the outbound rules in the firewall.
...this is NOT the log (as in PlexConnect.log), but the terminal output, right?
Please attach/link to the file, it contains more data points.
https://dl.dropboxusercontent.com/u/108823/PlexConnect.log
Bump.
Since your aTV already has contact to PlexConnect/PMS it's not a Cert issue...
Did I understand you correctly, that you WON'T see the movie list? The last XML in the logs should be the movie posters with "recently added", "recently released". Is that the one you don't get?
Please do me a favor, create a fresh section in PMS, add a couple of movies (about half a dozen?) and try again. I didn't find anything offending in the log so far...
