Accessing Trailers issue
I have been spending 2 days to test various methods and FAQs, forum postings, but still encounter the same issues. Desperately look for someone who can assist.
  • Your ATV model (2 or 3) and firmware version (found under the ATV settings > general > about > Apple TV software): 5.2.1 (6025)
  • The DNS server set on the ATV (found under the ATV settings > general > network > DNS): 192.168.0.102
  • The device and operating system (including version number) that PlexConnect is installed on: Windows 7, PC
  • The local IP address of the device that PlexConnect is installed on: 192.168.0.102
  • The device and operating system (including version number) that the Plex media server (PMS) is installed on: PC, Windows 7,
  • The Plex media server (PMS) version number you are running (**do not put 'latest'**): 0.9.7.28
  • The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.0.102
  • The PlexConnect version number. If using Github source then a time and date of download (look at the creation date of the folder) and if you are using any testing branch e.g. the Elan/PlexInc one. Downloaded on June 30 2012 19:20 (+8.00) and tested on Elan/PlexInc version.
  • The content of your 'Settings.cfg' file (if you do not have this file you are running an old version, please update)
  • Detail on the media file if it is an issue related to playing a media file (in order to get the necessary information on a particular media file go into the Plex web interface, select the video file, when it brings up the page for the media file click on the "i" information button on the left hand side, it will then bring up a "media info" box, click on the "View XML" button, it will then open a browser window with the relevant information, copy this to http://www.pastebin.com and use the pastebin link to post the details; posting the information directly in the forum may mess up the formatting and generally takes up a lot of space):
  • detailed description of the issue (the clearer you can make this the better): When tested on both versions of Plexconnect, click on all movies tab, the screen shows hourglass and "accessing trailers..." . Both ATV and PC are on ethernet. Tested on Wifi, but still no luck. DNS has changed to local ISP, after tested with Google default, both giving the same results.
Nobody... really nobody should have to edit settings.py. Not as python script and not hidden under a .txt extension...
Even the original settings.py is not working. :frowning:
I’m not really good in IT, only when the original settings.py is not working leave me no choice to test other method highlighted in this forum.
Sure it does... with the first clean run/shutdown, PlexConnect will create a settings.cfg file. This would be the place for your changes.
From your log:
>> 22:32:52 ATVSettings: add section 007
It really looks somewhat outdated. Would you please grab the latest from the link below and report back?
Thanks for the help. Will update and revert back once I’m back home.
Hi Rock Star,
Downloaded and installed with the latest version from the link.
Still encounter the same issue, but some channels which previously not working is now going well, and is just awesome.
As suggested by you, I have amended the cfg file instead of py file this time!  :D
Here is the log for your reference.
20:53:27 PlexConnect: started: 20:53:27
20:53:27 PlexConnect: ***
20:53:27 PlexConnect: PlexConnect
20:53:27 PlexConnect: Press ENTER to shut down.
20:53:27 PlexConnect: IP_self: 192.168.0.102
20:53:27 DNSServer: started: 20:53:27
20:53:27 DNSServer: ***
20:53:27 DNSServer: Starting up.
20:53:27 DNSServer: intercept trailers.apple.com: 192.168.0.102
20:53:27 DNSServer: forward other to higher level DNS: 1.9.1.9
20:53:27 WebServer: started: 20:53:27
20:53:28 WebServer: ***
20:53:28 WebServer: WebServer: Serving HTTP on 0.0.0.0 port 80.
20:53:28 PlexGDM: ***
20:53:28 PlexGDM: looking up Plex Media Server
20:53:29 PlexGDM: servers discovered: 1
20:53:29 XMLConverter: PlexGDM - PMS: 192.168.0.102:32400
20:53:43 DNSServer: DNS request received!
20:53:43 DNSServer: Source: ('192.168.0.100', 52784)
20:53:43 DNSServer: Domain: trailers.apple.com
20:53:43 DNSServer: ***intercept request
20:53:43 DNSServer: -> DNS response: 192.168.0.102
20:53:43 WebServer: serving application.js
20:53:43 WebServer: serving D:\PlexConnect-XML_templates\assets\plexconnect.xml
20:53:43 WebServer: serving  D:\PlexConnect-XML_templates\assets\js\utils.js
20:53:43 ATVLogger: loadItem: Library
20:53:43 WebServer: serving .xml: /library/sections
20:53:44 WebServer: serving .xml: /library/sections/1/recentlyAdded?stack=1&X-Plex-Container-Start=0&X-Plex-Container-Size=20
20:53:46 ATVLogger: loadURL (override): http://trailers.apple.com/library/sections/1
20:53:46 WebServer: serving .xml: /library/sections/1
20:53:46 WebServer: serving  D:\PlexConnect-XML_templates\assets\js\utils.js
20:53:46 WebServer: serving  D:\PlexConnect-XML_templates\assets\js\updateXML.js
20:53:47 ATVLogger: 1
20:53:47 WebServer: serving .xml: /library/sections/1
20:53:48 DNSServer: DNS request received!
20:53:48 DNSServer: Source: ('192.168.0.100', 61754)
20:53:48 DNSServer: Domain: a771.da1.akamai.net
20:53:48 DNSServer: ***forward request
20:53:48 DNSServer: -> DNS response from higher level
20:53:49 ATVLogger: 0
20:53:49 WebServer: serving .xml: /library/sections/1/all
20:54:22 ATVLogger: 1
20:54:22 WebServer: serving .xml: /library/sections/1
20:56:27 DNSServer: DNS request received!
20:56:27 DNSServer: Source: ('192.168.0.100', 59069)
20:56:27 DNSServer: Domain: bookkeeper.itunes.apple.com
20:56:27 DNSServer: ***forward request
20:56:28 DNSServer: -> DNS response from higher level
20:56:33 DNSServer: DNS request received!
20:56:33 DNSServer: Source: ('192.168.0.100', 61869)
20:56:33 DNSServer: Domain: upp.itunes.apple.com
20:56:33 DNSServer: ***forward request
20:56:34 DNSServer: -> DNS response from higher level
20:56:35 DNSServer: DNS request received!
20:56:35 DNSServer: Source: ('192.168.0.100', 61532)
20:56:35 DNSServer: Domain: mesu.apple.com
20:56:35 DNSServer: ***forward request
20:56:35 DNSServer: -> DNS response from higher level
20:56:37 DNSServer: DNS request received!
20:56:37 DNSServer: Source: ('192.168.0.100', 65334)
20:56:37 DNSServer: Domain: appldnld.apple.com
20:56:37 DNSServer: ***forward request
20:56:37 DNSServer: -> DNS response from higher level
21:07:48 DNSServer: DNS request received!
21:07:48 DNSServer: Source: ('192.168.0.100', 62611)
21:07:48 DNSServer: Domain: trailers.apple.com
21:07:48 DNSServer: ***intercept request
21:07:48 DNSServer: -> DNS response: 192.168.0.102
21:07:48 ATVLogger: loadAndSwapURL (override): http://trailers.apple.com/library/sections/1
21:07:48 WebServer: serving .xml: /library/sections/1
21:07:48 WebServer: serving  D:\PlexConnect-XML_templates\assets\js\utils.js
21:07:48 WebServer: serving  D:\PlexConnect-XML_templates\assets\js\updateXML.js
21:07:48 ATVLogger: 1
21:08:09 PlexConnect: Shutting down.
21:08:13 DNSServer: Shutting down.
21:08:13 WebServer: Shutting down.
